Dyno numbers before/after - FOUR FREE HP tips inside..
Old Apr 1, 2007 | 01:35 PM
vtec.dc2's Avatar
Default Dyno numbers before/after - FOUR FREE HP tips inside..
yeah right.. you get what you pay for.. but if you must, heres some secrets many may not know about!!
result may vary but 1-2hp is possible from each mod
1. turn your shift know so gears (1-3-5) are facing towards the driver side (this will reverse the polarity to ignition timing maps on ecu and optimize everything for max of performance). because its titanium, placing some electrical tape around the **** will free up some more hp (less interfierence with itr titanium piston retainers) .
2. adjust your lights all the way to dim (more voltage to the battery!!! more hp!!!)
3. the output of the battery will now be at 14.2 volts at all times
4. when driving on the road, roll both of windows down a little to build up wind turbulance, but allow more of a gap on passenger side - this way air will enter from drivers and exit through passenger recycling energy and propeling your hype r forward!
its of da h00k!
Old Apr 1, 2007 | 01:47 PM
cltitus's Avatar
damn how did you figure all this out. trial and error?
Old Apr 1, 2007 | 01:50 PM
vtec.dc2's Avatar
Default Re: (cltitus)
owners supplement manual. has to be ordered through helms
Old Apr 1, 2007 | 01:54 PM
cltitus's Avatar
how can i get ahol dof a helms i been looking just cant find
Casey's Avatar
Default Re: (vtec.dc2)
i found that you can port and polish your head if you do a WOT rev and suck in sand or bead from beadblasting. just make sure the sand is clean and youll be good to go. it blows through the exhaust when its done.
Old Apr 1, 2007 | 01:57 PM
cltitus's Avatar
Default Re: (Casey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Casey &raquo;</TD></TR><TR><TD CLASS="quote">i found that you can port and polish your head if you do a WOT rev and suck in sand or bead from beadblasting. just make sure the sand is clean and youll be good to go. it blows through the exhaust when its done.</TD></TR></TABLE>
that sounds like accident waiting to happen. Heat + Sand = Glass
Old Apr 1, 2007 | 02:08 PM
Doespike's Avatar
Default Re: Dyno numbers before/after - FOUR FREE HP tips inside.. (vtec.dc2)
Don't forget to have all your ITR stickers on the car! If you're missing any you won't create that slipstream effect which is the true reason ITRs are so great in the corners!
Also, make sure your VTEC solenoid is flushed weekly. If the fluids build up too much, they may have to catheterize heR
Old Apr 1, 2007 | 02:09 PM
Casey's Avatar
thats why you do it in quick spurts. its worked well for me in the past.
Old Apr 1, 2007 | 02:13 PM
cltitus's Avatar
Default Re: Dyno numbers before/after - FOUR FREE HP tips inside.. (Doespike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doespike &raquo;</TD></TR><TR><TD CLASS="quote">Don't forget to have all your ITR stickers on the car! If you're missing any you won't create that slipstream effect which is the true reason ITRs are so great in the corners!
dont forget spoon stickers add more then stock stickers.
Old Apr 1, 2007 | 02:29 PM
vtec.dc2's Avatar
Default Re: Dyno numbers before/after - FOUR FREE HP tips inside.. (cltitus)
also #5.. if you notice a lot of race cars use race tape around cracks/openings on the car.. when you off for a long trip, tape around your door jams and trunk area - more fuel efficiency and performance
Old Apr 1, 2007 | 02:37 PM
330R's Avatar
And always, always take a big dump before leaving the house for Race Warz!1lightweight
Old Apr 1, 2007 | 03:08 PM
dsisive407's Avatar
From: around the corner to the left ... no, your other left
Default Re: Dyno numbers before/after - FOUR FREE HP tips inside.. (330R)
#6 .. drive in a speedo .. the less you wear, the less weight you have to carry. Weight reduction ftw
RiskyPlays
May 17, 2019 07:45 PM
Rockale
11
Oct 5, 2014 08:11 AM
Sales@Bisimoto.com
Honda Insight & CR-Z Hybrid
377
Sep 2, 2013 01:40 PM
inspecta83
Engine Management and Tuning
Dec 11, 2009 07:01 AM
johng
12
Sep 30, 2002 10:06 PM
