PLZ HELP electrical issue?
ok heres what happened...i just recently swapped a ls into my 96 ek...well the battery is brand new...i will be going down the road or sitting...and all the lights will dim..the cd player will turn off..and the car will eventually cut off...its like the battery goes dead..i then wait 5-10 minutes..and turn the key back on..and everything is back as usual..working properly...fires right up...does anyone have the slightest clue what is going on? its crazy..!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackKready »</TD></TR><TR><TD CLASS="quote">could be a relay issue. ground possibly.</TD></TR></TABLE>
x2
Or your alternator might be dying.
x2
it is not the alternator for sure..i just pulled this mtoor out of a buddies car and i was having this same problem with my last motor...where is the relay u are referring too? i checked the grounds they are all good
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerosearch
» Search Results
Your search for wont start returned 324 results.
» Search Results
Your search for starting problem returned 108 results.
» Search Results
Your search for civic start returned 190 results.
» Search Results
Your search for start returned 265 results.
There, 887 threads for you to browse.
If you can't find it there I'll jump off a cliff.
» Search Results
» Search Results
» Search Results
» Search Results
i kind of have the same problem the guy i bought this car from used a lawn mower battery to run this and well when im running the car sometime my MPH gauge is bouncing up and down out of control. and then it goes away just time to time mainly when my lights are on. could it be my battery (most likely but making sure)
mycivicswaylow53
Dec 20, 2007 04:15 PM
Slow Egg
31
Jan 14, 2004 04:52 PM
