starting problem...
Whenever I go to start my car, nothing happens. The engine won't turn. The starter was replaced about 3 months ago and I even hit on that to see if that was the problem but no luck. Anybody have any suggestions to get the thing started?
Engine wont turn eh?
Try your battery, check your plugs/wires
make sure your dizzy is okay and hasn't been flipped around or anything.
I'm betting on the battery though.
I also had problems with the fuel system earlier in the week... i think. The car was trying to start but wouldn't. So i replaced the coil... that wasn't it. So when i would try to start it if i gave it a little gas it would start. And now it won't do anything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hon da top »</TD></TR><TR><TD CLASS="quote">Don't think its the battery, the stereo, lights, everything will turn on but the engine won't turn. </TD></TR></TABLE>
That doesnt mean jack, you're battery may not have enough amperage to turn the crank. Turning the crank requires much more powertha your radio and lights.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hon da top »</TD></TR><TR><TD CLASS="quote">I also had problems with the fuel system earlier in the week... i think. The car was trying to start but wouldn't. So i replaced the coil... that wasn't it. So when i would try to start it if i gave it a little gas it would start. And now it won't do anything.</TD></TR></TABLE>
Giving a fuel injected car gas to get it to start won't do anything.
Lemme get this straight, you replaced the coil in the alternator for a fuel problem?
Have you taken it to autozone to get your starter and battery tested?
Have you checked for spark? Is your fuel pump priming?
im having the same exact problems..i wrapped a wire around the little clip plug on the starter...then tapped it to the positive post on the battery and the car will crank...if i try with the ignition it just sits there..idk wtf is goin on
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackKready »</TD></TR><TR><TD CLASS="quote">you need a starter dude , starter solenoid is done , happens alot.</TD></TR></TABLE>
How are you so positive over the internet? It could be the solenoid or 60 other things.
IMO I would rule out the solenoid on a new starter.
I've told you everything I can think of. I'm spent bro.
https://honda-tech.com/zerosearch
» Search Results
Your search for wont start returned 324 results.
» Search Results
Your search for starting problem returned 108 results.
» Search Results
Your search for civic start returned 190 results.
» Search Results
Your search for start returned 265 results.
There, 887 threads for you to browse.
If you can't find it there I'll jump off a cliff.
» Search Results
» Search Results
» Search Results
» Search Results
< me
