possible to run 440's on a chipped pm6 with just a MPFI?
Had the car turboed but had to take it off for a few different reasons.. I plan to put the turbo back on in 3 +/- weeks but don't have any injector o-rings to run the stock injectors. I was wondering if its possible to run 440's with a chipped pm6 and have it run right with only an MPFI swap. I have an idea on how to do it in turboedit but not sure if it would work or not.. lmk
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daveb91 »</TD></TR><TR><TD CLASS="quote">Yes turboedit maybe get someone to get you a stock bin but redone for 440s. Xenocron, blundar, pgmfi site....</TD></TR></TABLE>
ok thanks, i posted on the pgmfi site
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90nhcrxsi »</TD></TR><TR><TD CLASS="quote">Its possible I ran 440cc dsm blue tops in my obd-0 turbo sohc zc swapped dx civic hatch, had it street tuned with turbo edit </TD></TR></TABLE>
mine isnt turboed... I had it turboed but took it off until I can get some money to get it tuned. I'm in alot of debt right now from my other transportation breakin while the hatch wasnt running.
I solved the problem tho, I found some o-rings for stock injectors so I just threw the stock injectors in
If all you did was remove the turbo the car will still run fine. The ECU will not see boost with no turbo, so it will run just like you were cruising down the road. No need to change anything
bewstn ex
Mar 16, 2008 07:01 PM
