gsr swap into ek hatch
I have a 96 gsr that i had put into a 96 cx hatch. I used the hx harness with a obd 2 to 1 jumper harness p28, but now my car is miss firing. Check engine came on and the code was the idle air control and i've replace that and it still missing. I've replaced a couple of thing that i thought was the problems but still missing. Thanks for any help!!!!
Things i replaced: fuel filter, idle air control, dizzy, changing ecu but still miss.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kwazigoku »</TD></TR><TR><TD CLASS="quote">i finally got the car started but know the rpm jumps??? wat can cause that problem??</TD></TR></TABLE>
a lot of different things.
Start with the free things, like check for vacuum leaks, clean the IACV and FITV. Clean the throttle body, some injecotr cleaner wouldn't hurt either. I reccommend seafoam for injectors.
civicguy167
15
Dec 3, 2013 08:45 PM
Kanaloa5305
Jan 30, 2012 03:58 PM
