ls ecu problem
Old Apr 1, 2007 | 01:27 AM
jdmDRIFTER's Avatar
Default ls ecu problem
When I attach the LS B18a1 ECU to the car it starts then dies. What is the problem? Then after I plugged the SOHC D15b1 ecu in it started and ran but only on two cylinders problem do to it being made for DPFI. I do have the OBO-0 to OBO-1 conversion harness so how do I get this to work for MPFI!
Old Apr 1, 2007 | 06:20 AM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
bump for a local....i would like to know this too...
Old Apr 1, 2007 | 08:05 AM
davens's Avatar
Questions:
1. You did a full dpfi to mpfi conversion?
2. You're using all the correct obd-1 components i.e. o2 sensor, distributor etc?
Old Apr 1, 2007 | 10:58 AM
Malgerus's Avatar
Default Re: (davens)
Solid code when you turn the ecu to the on position?
ecu could be dead, just a thought
Old Apr 1, 2007 | 11:02 AM
MasterGDP's Avatar
Default Re: (Malgerus)
any broken pins? you got all the obd2 parts?
Old Apr 1, 2007 | 12:46 PM
jdmDRIFTER's Avatar
Dead ecu might be it but I think I will check the wires out first
Old Apr 1, 2007 | 09:27 PM
jdmDRIFTER's Avatar
Default Re: (jdmDRIFTER)
Should I still continue to use the SOHC ecu? I believe it may work if I rewire the dizzy
scussett
Aug 12, 2008 07:33 AM
mawkiemarc
22
Feb 28, 2006 12:21 AM
Hybridize
Oct 19, 2003 05:10 PM
integranator
Aug 7, 2003 12:40 PM
