jdm cluster problem
Old Mar 31, 2007 | 09:57 PM
jayturboef's Avatar
Default jdm cluster problem
i just put a 90/91 jdm cluster in my 89 crx every thing works fine execpt my temp gauge ..as soon as the key is turned on the temp needle goes to the top... i also keep having my dimmer switch from blowing out when i use it for more than one minit after pluging it it .... i have checked my wiring 2 times allready and every thing is right including the grounds...if anyone has any problems like this please help
Old Apr 1, 2007 | 09:42 PM
jayturboef's Avatar
anyone???
Old Apr 2, 2007 | 09:22 PM
EF_LSVtec's Avatar
Default Re: jdm cluster problem (jayturboef)
something is obviously wrong... what color wire do you have connected to the temp gauge behind your cluster? I would trace that and maybe you just interconnected a couple of wires.
this is the link that I used when I did my swap..
http://b16a.honda-perf.org/cluster.html
I hope this helps
JDM_WHR
Jun 13, 2009 11:42 AM
tommy.
12
Aug 29, 2006 05:27 PM
teler86
Apr 30, 2006 07:14 PM
5thgenallmotor
Dec 7, 2004 07:48 AM
