How can I get big old fatty welds on sch40 pipe?
Old Mar 31, 2007 | 09:26 PM
*Boostwerks*'s Avatar
Default How can I get big old fatty welds on sch40 pipe?
I'm just really curious as to how Cody and the guys at full-race (not the robotic welds) are able to get such large and fat welds on stainless pipe without burning the material. Do they use something like 1/4" filler, 300amps and dip like theres no tommarow?
I'd like to figure out how to do this because, the welds are obviously strong as hell, it looks like it takes far less time to weld a joint, and...it simply looks very cool.
TIA,
Bryson
Old Mar 31, 2007 | 10:46 PM
CoreyR's Avatar
Default Re: How can I get big old fatty welds on sch40 pipe? (Boostwerks.com)
im pretty sure codys welds look like that because he walks the cup. so ive heard anyways.
Old Mar 31, 2007 | 10:58 PM
k24em2's Avatar
Default Re: How can I get big old fatty welds on sch40 pipe? (CoreyR)
Thats a definite walking the cup weld.
Old Mar 31, 2007 | 11:34 PM
TurboJesse
Guest
Posts: n/a
big welds aren't always stronger...you can also put too much heat into the material.
Old Apr 1, 2007 | 06:20 AM
weiRtech's Avatar
OG Fabricator
not to criticize, but is there some sort of testing done on these welds with results showing strength? i'd base weld strength on testing, not so much on if it looks cool.
wade's Avatar
I hear if you work the torch in a small circular motion to get a wider puddle and then dap thats how its done?
Old Apr 1, 2007 | 07:12 AM
TOFU.man's Avatar
Default Re: How can I get big old fatty welds on sch40 pipe? (TurboJesse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboJesse &raquo;</TD></TR><TR><TD CLASS="quote">big welds aren't always stronger...you can also put too much heat into the material.</TD></TR></TABLE>
Well put! To add your statement, it also leaves more room for inclusions (error) which can be fatal to a weld.
Old Apr 1, 2007 | 08:44 AM
9bells's Avatar
OG Fabricator
Default Re: How can I get big old fatty welds on sch40 pipe? (TOFU.man)
Big welds are not stronger. Having a cap that is too hight causes problems with stress-flow lines. It's like a small notch-effect.
That is the reason most weld certifications ask for a 1/8" cap height MAX.
The welds look good, just that they don't need to be that big.
Add all of the above info, and I don't think I would strive for that exact look.
Old Apr 1, 2007 | 09:17 AM
I've heard before....but
Someone needs to delete jaydmcrx's sticky'd "weld info" thread from the top of this forum then, because the information is wrong.
I've always been interested in trying to do the walk the cup method, but I have no idea how these guys can do it on such small pipe.
Old Apr 1, 2007 | 10:01 AM
dave@passenger's Avatar
I've tried walking the cup before, I don't think I have spent more than about 5 minutes on it any time before I just say screw this my HAZ area is outa control. Whenever I try to walk the cup the only way I have been able to get full penetration is by putting waaaay too much heat into the metal. I am not really sure what the advantage to walking the cup is supposed to be.
Oh well I hate big fat welds anyways I prefer tight.
Old Apr 1, 2007 | 10:09 AM
wade's Avatar
Default Re: (dave@passenger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dave@passenger &raquo;</TD></TR><TR><TD CLASS="quote">I've tried walking the cup before, I don't think I have spent more than about 5 minutes on it any time before I just say screw this my HAZ area is outa control. Whenever I try to walk the cup the only way I have been able to get full penetration is by putting waaaay too much heat into the metal. I am not really sure what the advantage to walking the cup is supposed to be.
Oh well I hate big fat welds anyways I prefer tight.</TD></TR></TABLE>
I also prefer it tight over fat and sloppy
Old Apr 1, 2007 | 10:33 AM
RCautoworks's Avatar
Default Re: How can I get big old fatty welds on sch40 pipe? (9bells)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9bells &raquo;</TD></TR><TR><TD CLASS="quote">Big welds are not stronger. Having a cap that is too hight causes problems with stress-flow lines.</TD></TR></TABLE>
As long as you keep the height of the bead down, you should be fine.
You usually do walking the cub on the second pass, which is not a penetration pass, more of a filler pass. So there really should be no reason for over heating the pipe on that pass, unless you are moving super slow.
Old Apr 1, 2007 | 12:57 PM
RC000E's Avatar
Default Re: How can I get big old fatty welds on sch40 pipe? (RCautoworks)
If that's walking the cup, then that's a method I've never seen. Walking leaves a distinctive weld pattern which looks like teardrops. That weld looks like a typical dab, move, dab, move weld. Plus, Full Race's "robot welds" do not walk the cup, and their welds are wide.
I have often wondered this myself. Do you pull the arc further away to spread the heat out, use big filler, maybe shape your tungsten with a blunt tip?
Another need for Engloid to be around.
Old Apr 1, 2007 | 01:06 PM
wade's Avatar
Default Re: How can I get big old fatty welds on sch40 pipe? (RC000E)
he isnt banned anymore, but he doesnt post
Old Apr 1, 2007 | 03:08 PM
CRXDrew's Avatar
Default Re: How can I get big old fatty welds on sch40 pipe? (wade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wade &raquo;</TD></TR><TR><TD CLASS="quote">he isnt banned anymore, but he doesnt post </TD></TR></TABLE>
Usually if a good welding question like this is asked in the HMT fab forum he usually chimes in outta nowhere.
Old Apr 1, 2007 | 05:53 PM
tony1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E &raquo;</TD></TR><TR><TD CLASS="quote"> Plus, Full Race's "robot welds" do not walk the cup, and their welds are wide.
.</TD></TR></TABLE>
The "robot" welds are not wide, they're very narrow.
Old Apr 1, 2007 | 05:54 PM
wade's Avatar
Default Re: How can I get big old fatty welds on sch40 pipe? (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">
The "robot" welds are not wide, they're very narrow.</TD></TR></TABLE>
agreed.//
VERRRY narrow
Old Apr 1, 2007 | 06:26 PM
Yeah walking the cup has this weave pattern in it. kinda looks like figure 8's.
Old Apr 1, 2007 | 06:38 PM
Their by-hand welds have seemed to get a lot wider though from what I've noticed. They're not nearly as wide as cody's in this case, but still much wider than some others. I don't really have a point with saying this...just a casual observation...
Old Apr 1, 2007 | 10:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostwerks.com &raquo;</TD></TR><TR><TD CLASS="quote">
The robot welds are very small on the full race, those collector welds are not robitic.
I actually brought this up with him about... well weeks ago. We talked about it and he had a lot of useful things to say, definitely if done right, there is nothing bad about it.
Old Apr 1, 2007 | 10:42 PM
RC000E's Avatar
Yeah, I think he figures the damage is done.
yeah...didn't realize that....well then all more the reason I'd like to know how to attain a wide weld like that. It'd come in handy filling a bevel that is a tad wider than usual.
Old Apr 1, 2007 | 11:43 PM
GTiR NX's Avatar
the advantage of walking the cup is speed. its much faster then dragging the cup, when one is proficient at it.
Old Apr 2, 2007 | 12:42 AM
MatrixGSR's Avatar
Default Re: (GTiR NX)
I do zig zags to spread the heat out. A lot of the heat comes from just the gas you use too. I have the welding company mix a big of oxygen into my gas. Usually makes my welds dime-up a bit better. Those guys make some pretty nice welds but fat welds aren't necessary. As long as it penetrates your good...
Old Apr 2, 2007 | 05:14 AM
tony1's Avatar
Default Re: (MatrixGSR)
You use an oxygen mix in your tig welder?
Old Apr 2, 2007 | 05:20 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks &raquo;</TD></TR><TR><TD CLASS="quote">
Thats why I said "by hand"
