I HAVE 92 VX 15DZ1 LIKE FLASH ECU
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SEBASTEAN929 »</TD></TR><TR><TD CLASS="quote">DOES ANY HAVE KNOWAGE ON THE MATTER OF FLASHING EUC OUR HELP !!!!!!</TD></TR></TABLE>
WHAT?
WHAT?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 19992civichatch »</TD></TR><TR><TD CLASS="quote">DOES ANYone HAVE KNOWAGE ON THE MATTER OF FLASHING the EUC need HELP !!!!!!
is that what u ment to say?</TD></TR></TABLE>
i think he meant to say
does anyone have knowledge about ecu codes [flash sequences]
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SEBASTEAN929 »</TD></TR><TR><TD CLASS="quote">DOES ANY HAVE KNOWAGE ON THE MATTER OF FLASHING EUC OUR HELP !!!!!!</TD></TR></TABLE> Me no Nintendo.
BTW your Caps is on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HA0LEFIED »</TD></TR><TR><TD CLASS="quote">
does anyone have knowledge about ecu codes [flash sequences]</TD></TR></TABLE>
I see alot of post asking for codes. well here is a list
Way to check codes on your 92-95 civic.
If you go to passanger side kick panel and raise up the carpet u sould see your ecu. and above your ECU there will be a lil plug. iIts grey. with 2 wires coming out of it. One wire is black with a white stripe and the other is a red with a black strip.. I take a spare piece of thin speaker wire and cut off both ends so that the actual copper of the wire is showion on both ends. i twist up both ends so that they are in a nice point. stick one end of the wire into the fist socket on the plug. The other end of the wire into the other socket. Turn your key to the ON position.. dont start your car. just to the ON position. Watch your check engine light on your cluster. it will flash.. 1 long flash is 10. the quick flashes are one. so if ur CEL goes !.....!!! that is a code 13. !....!....!!!!! code 25. then take the code #'s and hop on this thread and see what it is. i hope i could help you all.
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
or.......
https://honda-tech.com/zerothread?id=682412
16 Fuel injectors
23 Knock sensor
58 TDC sensor #2
or.......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SEBASTEAN929 »</TD></TR><TR><TD CLASS="quote">WHAT'S UP MAN I AM LOOKING FOR HELP ON FLASHING THE ECU ON MY 92 CIVIC VX ???????????</TD></TR></TABLE>
u mean like putting a new base map on it right? changing your red line and **** like that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pr0ject93hb »</TD></TR><TR><TD CLASS="quote">
u mean like putting a new base map on it right? changing your red line and **** like that?</TD></TR></TABLE>
thats what i was saying before, yet he still doesnt rephrase his question...
to the OP.
if that is your question, search for base maps, ecu, and flash in the archives, you might return something usefull
to the OP.
You CANNOT flash a stock ecu with out modification as in a chip. The only ecus that are currently flashable are the new ones for the k series engines (and a few others). But even that is mostly proprietary to the companies that have developed the maps and such so far.
I think thats your question. I have no idea.
I love lamp!
