pilot bearing
Is there a way to see if the pilot bearing is on the flywheel without pulling out the tranny? Maybe the clutch cover? I bought a new flywheel but forgot about the pilot bearing. When I went to go look in the box the flywheel came in, I didn't see the pilot bearing. The company I bought it from said it comes with it. So I'm hoping they put it the flywheel? kinda sucks to pull out the tranny again. Thanks
The pilot bearing is in the crankshaft. If you didn't pull it out, I'm sure it's still there. You will need to pull the transmission and clutch to get a look at it. How many miles are on your old one?
