gas leak
Old Mar 31, 2007 | 03:48 PM
STLblackcivic's Avatar
Default gas leak
i replaced my fuel filter and theres a leak when i start it...the new filter came with 3 washers (2 big and 1 small) but i only took off 1 big and 1 small from the old 1. so do i put both of the new big washers on for the new filter or is 1 just an extra?? also, the new washers are thinner than the old 1...and i already tightened the **** out of the banjo bolt so why the leak!
Old Mar 31, 2007 | 03:54 PM
sicones's Avatar
Default Re: gas leak (STLblackcivic)
the "big" washer, one goes on the top of the banjo bolt and one on the bottom, the little washer is if you have the fuel pressure test port on the top of the bolt, not all banjo bolts have this
Old Mar 31, 2007 | 04:00 PM
Default Re: gas leak (sicones)
so ur saying that the 3rd washer (the other big 1) is extra? i mean why would i have to put on 2 washers on one bolt right?
Old Mar 31, 2007 | 05:45 PM
ke98248's Avatar
bolt that bitch down hard too!
Old Mar 31, 2007 | 06:23 PM
sicones's Avatar
Default Re: gas leak (ke98248)
the fuel hose banjo fitting gets sandwiched between 2 crush washers, 1 on top, 1 on the bottom, and 25 lb/ft is not "bolt that bitch down hard"
Old Mar 31, 2007 | 06:32 PM
Yea i got it. that 3rd washer was an extra one. i just went back and tightened the **** outta the banjo and its no longer leaking. although im still bogging so i guess the real issue is the timing...but thanks all!
Old Mar 31, 2007 | 07:36 PM
ke98248's Avatar
well, most people really don't tighten the bolt down hard enough, and gasoline tends to leak or spray everywhere.. That's why I said that.
calvin924597
May 28, 2010 09:55 PM
Vadim_D
Jan 8, 2009 01:01 PM
Slvr_CRX
13
Apr 1, 2004 12:06 PM
Runsw4g4d
Sep 27, 2003 02:49 PM
Edward911
Feb 8, 2003 09:48 PM
