vtec rotors and calipers, will 15" ITR wheels fit...
So I want to upgrade to the larger vtec rotor, and in doing so, much convert to the vtec calipers. When I installed my ITR wheels, I needed spacers to make them fit, will they fit over the vtec rotors?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 »</TD></TR><TR><TD CLASS="quote">So I want to upgrade to the larger vtec rotor, and in doing so, much convert to the vtec calipers. When I installed my ITR wheels, I needed spacers to make them fit, will they fit over the vtec rotors? </TD></TR></TABLE>
They should fit fine. But I'd use spacers in them regardless of that. The offset is too high.
they definately need spacers, ask SleepyH22 about that one. He just installed ITRs earlier this week and had quite a surprise when the car tried to move off of the lift. By the way, would you know anyone who has a set of those wheels for sale????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GtechPro »</TD></TR><TR><TD CLASS="quote">
They should fit fine. But I'd use spacers in them regardless of that. The offset is too high. </TD></TR></TABLE>
Im using spacers now, Im aware of this, Im just worried about clearing the top of the caliper
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apex1972 »</TD></TR><TR><TD CLASS="quote">they definately need spacers, ask SleepyH22 about that one. He just installed ITRs earlier this week and had quite a surprise when the car tried to move off of the lift. By the way, would you know anyone who has a set of those wheels for sale????</TD></TR></TABLE>
nah, it took me a few months to find mine. I have been thinking of selling mine, but I just love the way they look.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amateur slot »</TD></TR><TR><TD CLASS="quote">MUST use spacers!!
they will not clear the calipers. i believe you need at least 5MM in the fronts. Rears fit fine with no spacers.</TD></TR></TABLE>
I already have spacers on them. I know, Im just wondering about the top of the caliper. I already have ITR wheels on my car. BUT, it is with the S/Si brakes. The vtec rotors are almost a full inch larger, that's where I am wondering if the caliper will hit the wheel, and I found out the hard way that you need wheel spacers. Tried grinding off some of the caliper, didn't work.
my car for reference.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amateur slot »</TD></TR><TR><TD CLASS="quote">you'll have no problems with it hitting anything on vtec rotors/calipers as long as you're running spacers.</TD></TR></TABLE>
yeah, i have 5 mm spacers on right now.
rear brakes are the same.
the different offset of the wheel is is what causes the caliper issues.
the original Si-VTEC wheel is a 15"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P13_mein »</TD></TR><TR><TD CLASS="quote">rear brakes are the same.
the original Si-VTEC wheel is a 15"</TD></TR></TABLE>
thanks man. Just wanted to make sure I could still use my current wheels.
my car for reference.</TD></TR></TABLE>
how much of a drop do you have??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LukieLuc »</TD></TR><TR><TD CLASS="quote">
how much of a drop do you have??</TD></TR></TABLE>
couldnt tell you, iits on coilovers
on a related note, if you need the components for the upgrade I can help you... selling brand new brembo blank prelude VTEC rotors plus the bigger prelude vtec / ITR calipers with pads.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 »</TD></TR><TR><TD CLASS="quote">Yea cory they fit, thats what I have on my car.
And yea I'm using 5mm spacers up front too.
pic in a minute
edit:
I used 5mm spacers all the way around, can u tell any diff. b/w the front and back?
pic in a minute
edit:
</TD></TR></TABLE>I used 5mm spacers all the way around, can u tell any diff. b/w the front and back?
ej_b16a
Nov 28, 2007 04:43 PM
BB6-213
May 21, 2006 09:11 AM
