battery cable and clutch to soft??
i just did a d16y7 in 91 crx si with new clutch but the clutch folk is way to soft?
and is there a diffence between 88-91 engine harness and last
where does the postive battery cable go to?
the post terminal goes from the battery to the second wire that goes up to the fuse block on the left hand side shock tower. there sould be a phillips screw and should the the spot thats closer to the motor side. hope that helps you pm if needed
drjondurst
Mar 30, 2003 07:16 PM
