changed distributor and car will not turn over?
Old May 25, 2002 | 06:31 PM
DALE-EK4's Avatar
Default changed distributor and car will not turn over?
i have 95 civic i did a jdm b18c swap in two weeks ago. the car started but after 15 minutes of driving i got a check engine light. the two codes i got were the cyp and ckp sensor. so i found out those sensors are in the distributor and can not be replaced. you have to replace the whole distributor. so i called honda motors online and they said they would swap the distributor for a new one. i got the new one today installed it with #1 cylinder at top dead center and now the car will not even turn over. after trying to crank the motor the speedometer goes crazy for a second. any help on this would be greatly appreciated this swap has costed my a ton of money and dont know what else to do.
Old May 26, 2002 | 05:34 AM
mugenracer's Avatar
Default Re: changed distributor and car will not turn over? (timnparts)
even with a busted distributor the engine should still turn, so i would say your problem lies elsewhere. Have you checked that your battery is fully charged?
Old May 26, 2002 | 07:52 AM
TurBoTeG's Avatar
Default Re: changed distributor and car will not turn over? (mugenracer)
Theres a fuse under your dash...check that..i think i had the same problem a few days ago on my buddy's civic....fuse was blown but the car wouldnt start but it WAS turning over...
EG_SINZ
Aug 13, 2013 03:37 PM
Dnelle95
11
Sep 23, 2011 08:36 PM
jrxiongs
Aug 26, 2008 03:06 PM
rodvang
Jan 9, 2008 05:45 AM
JDMSloLude
Feb 25, 2004 02:26 PM
