94 honda civic ex won't start
Old Mar 31, 2007 | 12:34 PM
speedswing's Avatar
Default 94 honda civic ex won't start
I've got gas and spark.
I've got 12v at the injectors
where is the ECU?
what else. Benn running fine the last year and just decided not to start for wife. Which is not good
Old Mar 31, 2007 | 12:52 PM
Archidictus's Avatar
Unceasing Measure
Default Re: 94 honda civic ex won't start (speedswing)
How do you know you have spark? What color is it? If it's not blue, your coil is probably on its way out. Are you sure your timing belt didn't snap?
Old Mar 31, 2007 | 01:04 PM
abs's Avatar
abs
Does your interior lights come on...hear any click coming from your starter? Any kind of noise come on when you try to start???
Old Mar 31, 2007 | 01:49 PM
Chumbas_EG9's Avatar
Default Re: 94 honda civic ex won't start (abs)
noises and sure its not a bad fuel filter?
Old Apr 1, 2007 | 10:36 AM
speedswing's Avatar
Engine cranks and cranks
I pulled the dist cap and got the crap shocked out of me on the rotor button when my wife was cranking it.
However, I pulled a plug and did not see any spark
I did smell gas on the plug.
I'm confused
Old Apr 1, 2007 | 11:44 AM
Hondacivic90ed's Avatar
pull your oil cap and have someone crank it and look through the valvecover to see if the camshaft is turning, if not = broken timing belt.
Old Apr 1, 2007 | 11:47 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: (Hondacivic90ed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondacivic90ed &raquo;</TD></TR><TR><TD CLASS="quote">pull your oil cap and have someone crank it and look through the valvecover to see if the camshaft is turning, if not = broken timing belt.</TD></TR></TABLE>
Or he could take the timing belt cover off.
Old Apr 1, 2007 | 12:03 PM
speedswing's Avatar
Default Re: (ek forever guy)
The valves are moving. I assume the timing belt is ok? I hope so probable less than 5k on the new belt.
Old Apr 1, 2007 | 12:04 PM
Ek Forever y0!
Default Re: (speedswing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedswing &raquo;</TD></TR><TR><TD CLASS="quote">The valves are moving. I assume the timing belt is ok? I hope so probable less than 5k on the new belt.</TD></TR></TABLE>
Then your belt should be fine.
Old Apr 1, 2007 | 12:21 PM
speedswing's Avatar
do these engines have a problem with the distributor?
I took the cap off to make sure the rotor button was spinning and it was.
any other ides?
Old Apr 1, 2007 | 12:22 PM
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerosearch
» Search Results
Your search for wont start returned 324 results.
» Search Results
Your search for starting problem returned 108 results.
» Search Results
Your search for civic start returned 190 results.
» Search Results
Your search for start returned 265 results.
There, 887 threads for you to browse.
If you can't find it there I'll jump off a cliff.
Old Apr 1, 2007 | 01:03 PM
speedswing's Avatar
I don't have a book. any place on the net where I can see a pic of where my main relays and such are?
I should be able to check it if I know where it is.
Old Apr 1, 2007 | 03:04 PM
speedswing's Avatar
I replaced ing mod and rotor button and cap then I had spark.
however, it turned over a good 30 sec before it caught and started.
I guess it's ok.
at least it's running
Old Apr 1, 2007 | 03:30 PM
VRD^don's Avatar
try new plugs..
Old Apr 2, 2007 | 06:46 PM
ya you're right taking off the timing belt cover is way easier then spinning the oil cap off and taking a look.
Mr learns alot
Feb 28, 2014 08:11 PM
skunkdgsr27
Feb 1, 2013 12:21 AM
JDM-sol 89
Feb 14, 2012 01:50 PM
lt1guy
Feb 14, 2010 07:06 PM
Rembrant
Aug 3, 2003 06:55 PM
