I NEED HELP
my EF9 got hit last night while i was asleep. Now on the driver side, the front tire instead of facing straight as it should be. Its facing into the car, towards the motor. Is it just the lower control arm and possibly the wheel berrings?!?!? I NEED HELP
probably need new upper control arm with ball joint.. probably upper ball joint, maybe a whole knuckle, possibly lower ball joint. might have chassis damage. yaaaaaaaaaaaaaa good juck with that.. take it to a shop and see what you need.. dont just rig it up. please.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef9owner »</TD></TR><TR><TD CLASS="quote">any other suggestions?</TD></TR></TABLE>
Get the frame on a frame machine. You might have bent the frame rails then the car is junk unless you got deep pockets to get it straightened (I beleive a machine of that nature is about 80$ an hour).
Replace the whole front suspension with one that hasn't been nailed on the side (bargain with an auto wreckers, usually you can pick up a full front suspension for about 100$).
there is no way we are going to able to tell you exactly whats wrong with your car.
it should be pretty obvious to you when you remove the wheel, what parts are damaged.
if you can get pics that will help a lot. it can be more then one thing, or just be one little thing. not all situations are the same.
globy123
Aug 10, 2013 09:55 AM
highneo
Dec 30, 2006 09:13 AM
hatchinprogress
Nov 16, 2004 05:24 PM
