Steel brake line question?
Old Mar 31, 2007 | 10:04 AM
ED9 Y-49's Avatar
Default Steel brake line question?
I reasontly instand some Russell steel brake lines and there are working great. My problem is when I put my wheels back on and went for a test drive I noticed a rubbing/clicking noise coming from my front end. I took my wheels back off to find that the lines got in the way and were rubbing aginst my wheel. It has striped the plastic lining from a section of the line on both sides in the front end. Will this be an issue for my stopping ability? Should I replaec them? I have heardthat the fluid can come through the steel and the plastic is what stops it. Thanks for your input.
Old Mar 31, 2007 | 11:40 AM
SiRay13's Avatar
Default Re: Steel brake line question? (ED9 Y-49)
it shouldn't be rubbing, there are supposed to be clips that hold the brake line in place, i think it's held in by two bolts.
Old Mar 31, 2007 | 03:12 PM
ED9 Y-49's Avatar
Default Re: Steel brake line question? (SiRay13)
The brake lines came with rubber clips in the middle of the line where they are suppose to bolt up, but the koni/ground control system that I'm running doesnt have places for this. So all I did was zip tie them to the control arm and went with it. Anyone have suggestions about my first question?
Old Mar 31, 2007 | 03:14 PM
Vitamin_b16's Avatar
pics will help....
but at first thought, you either got the wrong lines or you installed them wrong
da1lydr1ver
Dec 15, 2007 10:50 PM
MLRtimeSTL
Feb 6, 2007 02:17 AM
lowgman
Jul 21, 2005 10:13 AM
ActiveAero
Aug 3, 2004 07:31 AM
