Suspension & Brakes Theory, alignment, spring rates....
Bumpy Ride help!
Old Mar 30, 2007 | 10:12 PM
SoyMilk's Avatar
Default Bumpy Ride help!
my car is bumpy, it bounces up and down a lot , i am thinking its because of the tires or shocks..
any ideas what it could be
Old Mar 30, 2007 | 11:07 PM
SoyMilk's Avatar
Default Re: Bumpy Ride help! (ReFreSh)
bump!
Old Mar 31, 2007 | 12:16 AM
SoyMilk's Avatar
gettin bumpy
Old Mar 31, 2007 | 03:58 AM
SoyMilk's Avatar
no one knows the probable cause
Old Mar 31, 2007 | 07:41 AM
02 accord's Avatar
If you posted more info instead of bumping every hour, then you might get some help. Which springs/shocks/tires are you using?
Old Mar 31, 2007 | 02:40 PM
SoyMilk's Avatar
Default Re: Bumpy Ride help! (02 accord)
Modified by NotAvailable at 5:31 PM 5/3/2007
Old Mar 31, 2007 | 05:32 PM
SoyMilk's Avatar
bumpage
Old Mar 31, 2007 | 05:54 PM
PIC Performance's Avatar
What spring rates? When did you notice the change in ride quality? How old are the shocks? How low is the car?
Describe the "bumpiness" in detail or give an example or why you think its possibly the tires.
Old Mar 31, 2007 | 09:25 PM
SoyMilk's Avatar
Default Re: Bumpy Ride help! (PIC Performance)
1 finger gap between the fender and tires, it feels bumpy and not stiff like how it use to be. It bounces once you push down the car
Old Apr 1, 2007 | 10:03 AM
SoyMilk's Avatar
Old Apr 1, 2007 | 12:44 PM
SoyMilk's Avatar
infi
Old Apr 1, 2007 | 01:18 PM
spoon_ek9's Avatar
for a stock replacement shock(which tokico blue is) lower that low, it will constantly ride on the bump stop or even constantly bottom out, that is why your ride is bumpy
Old Apr 1, 2007 | 02:30 PM
SoyMilk's Avatar
Default Re: Bumpy Ride help! (spoon_ek9)
so, are my shocks blown by riding low? and should i get new shocks? that arnt oem replacement
Old Apr 1, 2007 | 02:43 PM
spoon_ek9's Avatar
the bottom line is, u have to look at where u want the car seat at(how low) and see if the shock still have travel with that height. what shock or setup will be good is all depend on individual liking.
Old Apr 1, 2007 | 04:30 PM
Gc8_nate's Avatar
when you say bouncy...
when you hit a large bump does it bounce after for a while or do you mean its just a rough ride? Because depending on your tires it will seem bouncy on a rough road.
Koni's/ground controls and toyos is quite a bumpy ride for me on rough roads so that might be all your expeiriencing
Old Apr 1, 2007 | 04:48 PM
SoyMilk's Avatar
Default Re: (Gc8_nate)
i dont mean stiff like yours,
even when i am on a good straight road, it tends to bounce
Old Apr 1, 2007 | 05:59 PM
Gc8_nate's Avatar
then your definently just riding on springs, either bad shocks or your too low on the blues and riding on the bumpstops as was said
Old Apr 1, 2007 | 07:12 PM
SoyMilk's Avatar
so new shocks ? i hav coilovers
Old Apr 2, 2007 | 12:09 PM
b18LS's Avatar
Default Re: (ReFreSh)
raise the car up about .5 inch first. You might find it helps maybe tired shocks feel healthier. If you like the ride and can live with the looks, get it realigned....If not, get some illuminas.
hybrid90
Suspension & Brakes
15
Mar 21, 2009 06:33 AM
Mafooney
31
Dec 26, 2006 02:16 PM
6shootahorsenamedtrigga
Suspension & Brakes
16
Sep 16, 2006 07:14 AM
srv3fender
Suspension & Brakes
May 12, 2005 08:19 PM
kingseth2
Aug 17, 2003 01:54 PM
