brake swap for front 90 hf
Old May 25, 2002 | 04:54 PM
90TegRex's Avatar
Default brake swap for front 90 crx hf
I also posted this in the "tech" area with no response yet... sorry 'bout the doulbe post...
I'm about to swap in a b18, and discovered that I also need to replace the hubs on the front to use the axles. I planned on replacing the brakes, but I was just wondering two things...
1) If I just do the front brakes, do I have to change the master cylindar and p-valve? (I plan on doing it asap, but I'm on a tight budget)
2) If I have to replace the MC, will the MC from a 90 Integra with abs work? It also has another piece for the abs, but will the MC and booster work without it?
BTW: All of the components, axles, calipers, rotors, etc are comming off of a 90 Acura Integra GS (w/abs).
Thanks for the input
[Modified by davija, 1:55 AM 5/26/2002]
Old May 25, 2002 | 08:26 PM
wickedxboi's Avatar
Default Re: brake swap for front 90 crx hf (davija)
just get the hubs and you should be ok. i dont know about the abs though. i have 93 gsr brakes on there with the stock mc and my other friend has 91 ls front brakes on his. both crxs. hope this helps
remoer
Feb 16, 2008 04:07 PM
RickChew
Mar 4, 2003 07:29 AM
90TegRex
May 26, 2002 07:13 AM
90TegRex
May 25, 2002 10:08 PM
