WHAT'S THE RIGHT TURBO???
What's up everybody, i'm new here. I'm here to get some help and advice on what turbo to get for my B16 Crx. I was told to get the Garrett T3/T04E 57 Trim. Now I don't really know much about this stuff but here are the specs:
Compressor Specs:
- T04E housing 2-3/4" inlet 2" outlet
- 57 trim T04E compressor wheel 2.23/2.95 45lb/min
Turbine Specs:
- T31 4 bolt outlet turbine housing available in .48, .63, and .82 A/R ratios
- 76 trim T31 turbine wheel (stage 3)
Like I said I Don't really know what all this stuff means but I was also told to get .60 inlet and .63 exhaust. This turbo is good for up to 475-500 hp. But I really don't want that much hp, I'm doing it on stock internals. so i'm probably gonna run about 8-10 psi. I was looking at the turbine wheel it says it's 76 trim, stage 3. Is that too much??? HELP PLease!!!!!!
Compressor Specs:
Turbine Specs:
You should match your turbo to your power goals and engine size (the amount of air needed at a given rpm to make that power). It’s about understanding the theory behind forced induction and being able to read the “turbo map”.
Here is a good link about turbo maps https://honda-tech.com/zerothread?id=142398
A real elementary way of explaining turbos is the lager the turbo the more power it is capable of making and will spool up later in the rpm band. A smaller turbo will make less power and spool up sooner in the rpm band. Journal bearing turbos spool later in the rpm band than a similar sizes ball bearing turbo. The better the match, the happier you be with the end result.
I have a gt2871r and probably would have been better off with the gt28rs for my power goal of 300 hp. It spools a little later but still makes good power around 4000rpm on a b16.
There is a lot a tuner can do to make up for some of the shortcomings of a given turbo. I would suggest finding a competent tuner around where you live and talk to him about your goals and his experiences. Map out a plan and you should have a good set up in the end.
get ahold of <u>Maximum Boost</u> by Corky Bell and read it.
learn to read a compressor map.
i am serious. if you want to DIY your turbo system, you must educate yourself if you don't want to waste your time and $$
underpressure02
Feb 10, 2004 07:26 AM
blufke
Oct 9, 2002 11:23 AM
