whats wrong with my lude?
Old Mar 30, 2007 | 04:36 PM
Silencer RPMs's Avatar
Default whats wrong with my lude?
i didn't notice till yesterday that my right side is like 2 inches closer to the fender then the left. my balance is all fucked up, and before i went to work i was gonna take the tire off and as i tried the tired shifted back and forth when i was trying to take it off. i was running late for work so had to go. what could it have been?
Old Mar 30, 2007 | 04:44 PM
BlownH23a
Guest
Posts: n/a
Default Re: whats wrong with my lude? (Silencer RPMs)
wtf...dude your making no fkin sense. Explain in clearly wtf is the problem please.
From what im deciphering out of your message there, sounds like your hub is done.
Old Mar 30, 2007 | 04:47 PM
nonvteclude's Avatar
closer to the fender how? to the front, back, outer?
Old Mar 30, 2007 | 04:58 PM
Default Re: whats wrong with my lude? (nonvteclude)
to the back of the fender. its 2 inches closer then the left tire. and it moves back and forth when i try to take the tire off.
Old Mar 30, 2007 | 05:09 PM
the radious rod bushing could be crushed causing it to be to close to the rear. front to back or out and in?
Old Mar 30, 2007 | 10:38 PM
front to back man
Old Mar 30, 2007 | 10:53 PM
ninja 6's Avatar
me no speaka engles!
Old Mar 31, 2007 | 12:24 AM
ethereal2pt2's Avatar
Default Re: whats wrong with my lude? (Shiny Toy Gun)
pictures speak a thousand words. words you seem to have problem using.
Old Mar 31, 2007 | 01:44 AM
ninja 6's Avatar
Default Re: whats wrong with my lude? (_BB6)
it could be a ton of things. post pics, post symptoms, and be more clear and concise with your original post. it will help you down the road
Old Mar 31, 2007 | 08:50 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silencer RPMs &raquo;</TD></TR><TR><TD CLASS="quote">front to back man</TD></TR></TABLE>
check your radious rod bushings, check the mounting point on the lca. check for anything broken, loose or crushed.
mish__
Suspension & Brakes
Mar 3, 2013 12:08 PM
talkJDM
Suspension & Brakes
13
Jul 25, 2011 06:20 AM
zach1288
39
Aug 3, 2007 08:22 PM
alfaaay
Nov 11, 2003 11:32 AM
Uncle_Ben
Jun 27, 2002 07:53 AM
