bouncing idle in 93 hatch
hey guys, i just put my engine.. d15b7 block with d16z6 head..started it up, has a really bouncy idle. Checked TPS and voltage is .458 closed and will get to 4.5ish full throttle. I also have 5 volts power going to tps.. I also checked continuity with all the wires from the MAP sensor to ecu and no broken wires.
what else would cause this? i know vaccum leaks, but im pretty sure everything is sealed nice and good. i gnuna get some starting fluid to check leaks out. im throwing a code 19 (which has to do with the auto ecu im running untill i buy a p28, I did an auto-manual swap)
any ideas would be very greatful. thanks
alextech
12
Nov 24, 2018 06:29 AM
jrhcivak
14
Jul 24, 2012 05:06 PM
