available gains from b16 head on b18c?
Old May 25, 2002 | 03:47 PM
Wide Open Throttle's Avatar
Default available gains from b16 head on b18c?
what sort of gains are available from a b16a head on a gsr block? is an obd-II head necessary for an obd-II gsr block? are b16 cams more aggressive than gsr cams?
all input welcome, tia
Old May 25, 2002 | 04:40 PM
mattL's Avatar
Default Re: available gains from b16 head on b18c? (Wide Open Throttle)
the advantages for a b16 head are that you can bolt up an ITR manifold and they flow a little better, the gsr cam is more aggressive than the B16.
Old May 25, 2002 | 04:43 PM
CRX_VTEC's Avatar
Default Re: available gains from b16 head on b18c? (mattL)
the only up side is that a Type R IM will bolt up. Other then that...why do it?? B16 cams arent as aggressive. And you loose compression. So why??
Old May 25, 2002 | 05:03 PM
Tweakmeister's Avatar
get type-r pistons and type-r cams and do a P&P
Old May 25, 2002 | 05:13 PM
B00ST2nR's Avatar
Default Re: available gains from b16 head on b18c? (Tweakmeister)
or you can just get a Skunk2 IM without having to go through the trouble of doin all that head swap...
Old May 25, 2002 | 09:03 PM
jdm_latino's Avatar
Default Re: available gains from b16 head on b18c? (b18c1 dc2 R)
just like he said
Old May 26, 2002 | 03:00 AM
IgniteTeg's Avatar
Default Re: available gains from b16 head on b18c? (jdm_latino)
Just get a Skunk2 Im and ctr or itr cams and Skunk2 gears or whichever you like to dial in.
Old May 26, 2002 | 04:24 AM
ALF's Avatar
ALF
If you don't have high HP, the benefits of a B16 head are little to nothing. Stick with the GS-R head.
Old May 26, 2002 | 06:13 AM
Chubz's Avatar
Default Re: available gains from b16 head on b18c? (ALF)
the only advantage of a b16 head ober the GSR head is that the b16 head allows more volume, and compression is .2 or .3 less than a GSR head. Due to the smaller combustion chamber of a GSR head.
Old May 26, 2002 | 07:22 AM
SCsol's Avatar
Default Re: available gains from b16 head on b18c? (SuperTech)
P&P your GSR head and get a Shunk@ or JG maniflod dont waste your money on anther head
Old May 26, 2002 | 09:23 AM
pny's Avatar
pny
Default Re: available gains from b16 head on b18c? (lowsol)
i second that...
GSR heads are better then B16's
Old May 26, 2002 | 09:41 AM
Default Re: available gains from b16 head on b18c? (pny)
why do people always use b16 heads for b20/vtec and ls/vtec conversions? why not use the gsr head?
this motor is planned for forced induction, so it would be more advantageous to have less aggressive cams. a turbo would also benefit from a lower compression.
so the b16 head, intake manifold, and throttle body do or do not flow any better than the gsr?
[Modified by Wide Open Throttle, 6:48 PM 5/26/2002]
Old May 28, 2002 | 10:21 AM
Old May 28, 2002 | 10:44 AM
ingrate's Avatar
25 Year Member
people use b16a heads because they are more abundant and are also cheaper
Old May 30, 2002 | 12:16 AM
IgniteTeg's Avatar
Default Re: available gains from b16 head on b18c? (In7egrity)
i 2nd that
Old May 30, 2002 | 06:19 AM
X2BOARD's Avatar
Default Re: available gains from b16 head on b18c? (IgniteTeg)
I'm looking to swap a B16 head onto a B18c block too... but then again, I want to lower the compression some.
The heads are interchangable with no modification necessary right ?
d16turbocoupe
12
Aug 29, 2010 10:33 PM
nix94delsol
Jul 29, 2007 06:52 PM
Unsought Devil
Nov 11, 2006 04:57 PM
SOHCZCHatch
Nov 10, 2004 05:45 PM
Malice
Mar 6, 2002 07:29 PM
