RuBbin
Well on my accord that i just got the wheels are rubbin in the back bad. One of them th had to take off. So i was wondering where can i get a machine to roll my finders or wut can i do to do that without f*&kin up the paint
its not lowered but i think that it has spacers on it right now
i have to take it apart some more to see wuts all under there. I have to get a clutch and new struts next. And i am sellin 2 sets of wheels plus 2 cars so i am going to be bankin soon
what size is your wheel and tire and your offset. if your not lowered you shouldnt be rubbing, instead of rolling your fenders and band-aiding the problem, fix the source, which is wrong sized wheels+tires.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pos_cd5 »</TD></TR><TR><TD CLASS="quote">what size is your wheel and tire and your offset. if your not lowered you shouldnt be rubbing, instead of rolling your fenders and band-aiding the problem, fix the source, which is wrong sized wheels+tires.</TD></TR></TABLE>
lol your not even lowered and your rubbin id get some new wheels before you start to lower it... or get thinner tires
edit: there is a machine you can use but it cost about 5 bills or less forgot go to the body and have them do it or you can use a baseball bat and heat up the paint and you should be good
i went and got sum teporary wheels off my boy brian. He has a turbo 240 , w/everything that **** is ballin, and he got a 5 lug conversion to fit his trifore zelda wheel. So i hooked him up with sum more tires to drift in and he hooked me up with all the wheels and the tires. I have to go get them from sumwhere but it was all worth it when i got them. I still need to find sum wheels though. On drag.com i was looking at the DR2's that look pretty ballin
Well what color is your car? And you do realize those are drag racing wheels.....the only ones I saw were 18x7, and if you get those you're going to have to get hella low pro tires to not rub, all the more so if you lower your car. I'd stay with 17" max.
