what type of file do you use on file to fit rings?
Old Mar 30, 2007 | 07:23 AM
92redhatch's Avatar
Default what type of file do you use on file to fit rings?
i know it sounds like an obvious answer.( any file that works) But i wanted to know what type of file would make my life a little easier when filing my rings to the correct gap.
Thanks,
Mike
Old Mar 30, 2007 | 09:11 AM
Padawan's Avatar
Darth ModerVader
Default Re: what type of file do you use on file to fit rings? (92redhatch)
There are speciality ring filers that are designed for the task. I've never personally used one, but I would imagine it's the best solution if you're looking for an easy method.
Old Mar 30, 2007 | 09:41 AM
92redhatch's Avatar
were would i buy one? Napa?
Old Mar 30, 2007 | 09:49 AM
Padawan's Avatar
Darth ModerVader
Default Re: (92redhatch)
I'm not sure if Napa would carry them, but you can check. This is an example of the kind that I'm referring to: http://www.etoolcart.com/brows....html
Old Mar 30, 2007 | 10:03 AM
92redhatch's Avatar
thanks is there any other type of file that works?
Old Mar 30, 2007 | 12:25 PM
SlowReaction's Avatar
Your going to want to use the ring filer like the one pictured. Check out summitracing.com. It might be cheaper there. Also when filing right make sure you only file one side and you filing inwards not outwards. Debure the ring before you install them.
stackz
Feb 21, 2005 01:48 PM
vtecturboteg22
Apr 25, 2004 04:51 PM
d styles
May 12, 2003 03:20 PM
boomslang
Oct 3, 2002 01:33 PM
se93
Oct 25, 2001 10:48 AM
