which is better
Old Mar 29, 2007 | 09:44 PM
crx_si-r's Avatar
Default which is better
ok im gettin ready to start puttin together my LS vtec tomorrow but im kinda thrown into a perdicament and wanted to see which one of the following two people prefer. for the ls vtec i have 2 b16 heads that i can use. the first being an OBD0 91 JDM B16A head and the 2nd being an OBD1 94 B16A3 head? this going to be matted to a 95 B18B1 and then be dropped into my 90 crx. does anyone kno of any pros or cons to using a JDM or USDM head? thanks everyone quick responses would be appreciated as im doin this tomorrow. oh yea another thing which would be worth more to keep un-used "as a spare" in the long run. thanks again
Old Mar 29, 2007 | 09:47 PM
cr-x-91's Avatar
other than it being a newer head...not much i believe....are the heads stamps both pr3?i know the cams on the obd1 head r better than the ones in the obd0
Old Mar 29, 2007 | 09:50 PM
EF_LSVtec's Avatar
Default Re: (cr-x-91)
like he said...newer better (most of the time)...
Old Mar 29, 2007 | 09:52 PM
.Manny.'s Avatar
Touching My Member
Default Re: (EF_LSVtec)
go with the newer one, the cams on the obd0 heads are pretty weak.
crx_si-r's Avatar
they are both stamped PR3
Old Mar 29, 2007 | 09:53 PM
cr-x-91's Avatar
if u want u can just send me tha old b16a head to me..ill take that junk off ur hands....hahaha
Old Mar 29, 2007 | 09:55 PM
cr-x-91's Avatar
there should be numbers on the ex side that read somthing like 9l9 or 0l0 and the first is 98-99 head and the other is 2000-01 head
Old Mar 29, 2007 | 10:00 PM
crx_si-r's Avatar
well by the vtec solonoid the newer onse has a 30 stamped on it which im assuming is a P30 its year is stamped 9l3 and the other one i kno is jdm beacause it has the older runners not like this one.
Old Mar 29, 2007 | 10:05 PM
cr-x-91's Avatar
run the newer one..newer is better...good luck on ur build man
lilxchris
Mar 16, 2009 04:18 PM
BryanM.
Mar 25, 2008 11:23 AM
EK99hatch
Jun 14, 2005 06:28 PM
b16a1sirhb
Sep 17, 2003 11:31 PM
