ECU in "limp" mode....
Old Mar 29, 2007 | 03:51 PM
krol's Avatar
Default ECU in "limp" mode....
wtf..... i tried the jumper trick to get the code..but the CEL just stays lit...my coolant temp sensor was broken off, so i replaced it and reset the ECU..and its still in limp mode!!
car is a '90 hatch si w/ b18a1
Modified by krol at 5:01 PM 3/29/2007
Old Mar 29, 2007 | 04:05 PM
onesikdb8's Avatar
Default Re: ECU in "limp" mode.... (krol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krol &raquo;</TD></TR><TR><TD CLASS="quote">wtf..... i tried the jumper trick to get the code..but the CEL just stays lit...my coolant temp sensor was broken off, so i replaced it and reset the ECU..and its still in limp mode!!
Modified by krol at 5:01 PM 3/29/2007</TD></TR></TABLE>
Are you running an OBD1 ECU?
Old Mar 29, 2007 | 04:18 PM
krol's Avatar
Default Re: ECU in "limp" mode.... (onesikdb8)
yeah..i think so anyway..i picked up the car on ebay already swapped from a deaf lady for $700
Old Apr 5, 2007 | 07:27 AM
krol's Avatar
when i reset the ECU the light doesn't go away even for a little bit...so..i would think that is something serious...no?
should there be a resistor box on the driver side right by the prop rod?-- there are a few wires that were just spliced together..and it seems like ive seen a resistor box up there on some swapped hatches..
thanks-- Dareck
Old Apr 5, 2007 | 11:39 AM
redefsir's Avatar
if your car has 4 injectors you need the resistor box
Old Apr 5, 2007 | 11:42 AM
ludesrv's Avatar
Default Re: ECU in "limp" mode.... (redefsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redefsir &raquo;</TD></TR><TR><TD CLASS="quote">if your car has 4 injectors you need the resistor box</TD></TR></TABLE>
Wrong. Don't spread incorrect info.
You need a resistor box if you are OBD0, obd1 and 2 do not need them.
Your wires are spliced togeter to eliminate the resistor box, that means you are more then likely OBD1. Check your ecu itself, does it have light gray, 2 rows of pin plugs? Those are OBD1 plugs. If you are running the old black plugs, you are obd0, and then you need a resistor box.
Old Apr 5, 2007 | 12:17 PM
krol's Avatar
Default Re: ECU in "limp" mode.... (ludesrv)
its obd1 then.. but what whoud make the ecu go into limp mode right away after being reset?..o2 sensor is good..i dont know what else would do it..
shytdoode
May 20, 2009 03:41 PM
RACEPAK
Nov 24, 2007 02:45 PM
punkracer
12
Nov 2, 2006 04:09 PM
CrxEDguY
Dec 6, 2004 09:51 AM
One8HatchAttack
Mar 31, 2004 11:43 PM
