Dynoed b16a2 ctr cams..
Old Mar 29, 2007 | 12:35 PM
hondalectual's Avatar
Default Dynoed b16a2 ctr cams..
I just wanted to get some input from you guys on the whp I made from the dyno the other day. I wanted to make sure if these numbers are were it's supose to be or what not and some advice on how much more hp I can achieve with some ctr pistons thrown into the setup I currentley have. here's the setup,
-usdm b16a2 with 114,xxx
-ctr cams
-stock headers with 2.25' egay header back exhaust setup. and everything else is stock.
I tuned it with crome started with jdm b16 map and got a/f between 13.5-13.9
the outcome was 159.02 whp and 112 ft/lb. I will post a dyno sheet later.
My goal is trying to make a low 13 sec pass using all honda oem parts for the b16.
Old Mar 29, 2007 | 03:15 PM
kangaroo's Avatar
that's pretty damn good for a b16 with just cams and nothing else.
I don't think you will run a low 13 with only 160whp though......unless you do some major weight reduction.
Old Mar 29, 2007 | 03:37 PM
4th-gen-civic's Avatar
Default Re: (kangaroo)
those are good numbers for that setup
Old Mar 29, 2007 | 05:53 PM
Timmay's Avatar
Default Re: Dynoed b16a2 ctr cams.. (hondalectual)
ditch the stock headers that will help alot.. also you should do a 2 layer headgasket to get a little more comp.. i did 159whp on my stock obd1 jdm b16a with just bolt ons and stock ecu.. that power in a light hatch should be good for 13's.. but if its a coupe i doubt it
Old Mar 29, 2007 | 10:31 PM
salman's Avatar
nice numbers.
Old Mar 30, 2007 | 12:00 AM
BOOSTEd2's Avatar
get a itr header, itr exhaust, b16b pistons, itr throttle body if you want to keep it all oem.
Old Mar 30, 2007 | 03:37 AM
1.8L_allmotormilitia's Avatar
not bad.
Old Mar 30, 2007 | 08:39 AM
Default Re: (1.8L_allmotormilitia)
Hey thanks guys. Well I guess i'll be ordering the ctr's and get a bit more compression and re-tune it then. If I do choose to mill my head what's the most I can take off b4 valve/piston come to contact?, I know the modification that has to be done to the b16 rods in order to fit them ctr's, but is there anything else I should do while half my motor is out? thanks h-t members.
Old Mar 30, 2007 | 09:53 AM
screw jdm.'s Avatar
Default Re: (hondalectual)
damn ctr cams make that big of a difference?
Old Mar 30, 2007 | 10:41 AM
Default Re: (fvck jdm.)
dude, what a newb I am. How da hell do i post a pic up in dis bitch? I wanna get that dyno graph up.
Old Mar 30, 2007 | 10:55 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondalectual &raquo;</TD></TR><TR><TD CLASS="quote">dude, what a newb I am. How da hell do i post a pic up in dis bitch? I wanna get that dyno graph up.</TD></TR></TABLE>
go to http://www.tinypic.com or http://www.we-todd-did-racing.com upload the picture and post it up with the [img][/img]
Old Mar 30, 2007 | 11:39 AM
BOOSTEd2's Avatar
just get the oem 3 layer hg and use only 1 layer you dont need to mill the head.
Old Apr 1, 2007 | 09:46 PM
salman's Avatar
those were new CTR cams or used??
Old Apr 4, 2007 | 09:20 AM
the cams were used.
Old Apr 4, 2007 | 08:38 PM
salman's Avatar
the stock CR of b16a3 is ???
Old Apr 4, 2007 | 08:45 PM
Timmay's Avatar
Default Re: (salman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salman &raquo;</TD></TR><TR><TD CLASS="quote">the stock CR of b16a3 is ???</TD></TR></TABLE>
10:2:1
Old Apr 4, 2007 | 09:38 PM
Dirtfall's Avatar
Those are very good numbers. I have ctr pistons and cams and i made 163 untuned. Your motor seems very strong. GL with your build
Old Apr 12, 2007 | 08:10 AM
92integraVTECgsr's Avatar
Default Re: (Dirtfall)
what dyno was that on?
I made 161whp with my JDM b16 XSi. AEM CAI, DC 4-2-1 Header, 2.25 Carsound Cat, RS*R ExMag Exhaust, ITR Flywheel.
Old Apr 12, 2007 | 09:45 AM
( o )( o )'s Avatar
Default Re: (92integraVTECgsr)
I'm glad to hear this.
I have a b16a2 with CTR cams, CTR pistons, maxbore'd TB, DC JDM 2.5", 2.5" exhaust....I was going for all OEM internals.
I should be well over 160 at the wheels. LOL i swear one of these days' i'll hit the dyno to find out.
Old Apr 16, 2007 | 08:35 PM
salman's Avatar
Default Re: (( o )( o ))
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ( o )( o ) &raquo;</TD></TR><TR><TD CLASS="quote">I'm glad to hear this.
We are waiting for that.
Old Feb 3, 2010 | 03:07 PM
cubanrider's Avatar
those are good numbers. I have this motor in my 90 da integra, and i did cams, pistons, rods, valves, exhaust, headers, pretty much everything, pushing almost 190 whp NA
Old Feb 3, 2010 | 10:51 PM
rhymeshark916's Avatar
RS machine pct's should do the job with oem bearings.
Old Feb 3, 2010 | 11:11 PM
.Manny.'s Avatar
Touching My Member
3 yr old thread noob. 190whp? dyno sheet or gtfo
sick93sol
110
Sep 7, 2009 09:07 PM
civic_fan
Feb 18, 2006 09:02 PM
MassScene
10
Mar 10, 2005 04:28 PM
crxste
Jun 24, 2003 06:13 PM
b18c-93
Mar 25, 2003 08:03 AM
