NEED HELP WITH MY SWAP WIRING.
Old Mar 29, 2007 | 11:35 AM
jdmhatch3's Avatar
Default NEED HELP WITH MY SWAP WIRING.
hey guys im having some trouble with my wiring. on the drivers side i have the grey box that has a green plug coming from it and a big white plug. problem is i have nothing to plug into THE WHITE PLUG. . and it appears to be the wiring for the fuel rail and injectors. does anyone know how to hook this up? its a 88 ef hatch with a b16a obdo.
Old Mar 29, 2007 | 11:51 AM
white94's Avatar
Default Re: NEED HELP WITH MY SWAP WIRING. (jdmhatch3)
the resistor box for injectors?
Old Mar 29, 2007 | 12:17 PM
jdmhatch3's Avatar
Default Re: NEED HELP WITH MY SWAP WIRING. (white94)
yes
Old Mar 29, 2007 | 12:19 PM
ludesrv's Avatar
Is the car already MPFI. If so all you need to do is add the vtec wires.
Old Mar 29, 2007 | 12:25 PM
jdmhatch3's Avatar
Default Re: (ludesrv)
yes it is but what does the big *** white plug go to? it looks like the plugs on the passenger side. but nothing to plug into it.
Old Mar 29, 2007 | 03:19 PM
jdmhatch3's Avatar
bump
Old Mar 30, 2007 | 04:44 AM
jdmhatch3's Avatar
ok i have everything that i can hook up electric wise hooked up except that white plug on the drivers side. i have all the vaccum lines hooked up except the one that goes from the back of the intake manifold to the brake booster. i started it but had to use starting fluid which leads me to think im not getting fuel. anywhoo it starts for about 20 seconds and then dies any ideas?
Old Mar 30, 2007 | 12:01 PM
jdmhatch3's Avatar
anyone? i cant hear the fuel pump so im guessing its not on. long story short i need help figuring out how to wire up all my fuel parts.
Old Mar 30, 2007 | 12:24 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (jdmhatch3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhatch3 &raquo;</TD></TR><TR><TD CLASS="quote">yes it is but what does the big *** white plug go to? it looks like the plugs on the passenger side. but nothing to plug into it.</TD></TR></TABLE>
It doesn't go to anything.
(760)doogie
14
Apr 22, 2008 06:55 AM
PINKS
Welding / Fabrication
Mar 3, 2007 02:35 AM
Iron_Forrix
Dec 30, 2006 09:32 AM
vitrox
Jun 14, 2004 05:40 AM
paybac4223
Jan 29, 2003 10:13 AM
