Bigger injector with S2 Pro 1 cams?
Old Mar 29, 2007 | 11:07 AM
RiceFed's Avatar
Default Bigger injector with S2 Pro 1 cams?
I dont know if this is a completely idiotic question or not but will I need to upgrade the JDM 345CC H2A injectors in order to flow enough fuel for the Skunk2Pro 1 Cams?
Im pretty sure I should be safe but I wanted to hear actual fact than my own opinion.
Motor is a stock block JDM h22a with ferrea valvetrain and all the bolt ons.
Old Mar 29, 2007 | 11:15 AM
jdmlude5
Guest
Posts: n/a
Default Re: Bigger injector with S2 Pro 1 cams? (RiceFed)
u will b fine
Old Mar 29, 2007 | 02:14 PM
InvaderTrax's Avatar
345's are fine on stage 1 cams
Old Mar 29, 2007 | 03:03 PM
98vtec's Avatar
moderator emeritus
Pro1 isnt really a stage1 cam. Its not a standard skunk2 cam. its the pro series which are more aggressive than that of the staged cams. I think you will be ok with a 345cc injector.
HyperFlow
Jun 6, 2010 11:55 AM
phaphon
20
Apr 25, 2010 08:49 AM
projsectEF
Oct 22, 2006 06:44 AM
rough_draft
Aug 22, 2004 12:00 PM
Tuan
Jan 15, 2003 10:23 AM
