Fuel mileage problem please help!!
Old Mar 29, 2007 | 10:59 AM
mysicivic1991's Avatar
Default Fuel mileage problem please help!!
i have d16a6 motor mostly everthing is stock. my fuel gauge is always going down when i hit the gas, when i am not in gear it goes back up again. i change my fuel filter, i have a cracked stock headers. Is it my cracked header causing me to use up more gas. idk, whats the problem pls help. thxs.
Old Mar 29, 2007 | 11:20 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: Fuel mileage problem please help!! (mysicivic1991)
Probably just that the bobber is bad in the gas tank. Mine fluctuates all the time when I'm below 1/2 tank. Now if your MPG is suffering, then you have a problem.
Old Mar 29, 2007 | 02:06 PM
sam385's Avatar
replace the caracked header, too, man.
Old Mar 29, 2007 | 02:18 PM
89efDUSTY's Avatar
Default Re: Fuel mileage problem please help!! (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">Probably just that the bobber is bad in the gas tank. Mine fluctuates all the time when I'm below 1/2 tank. Now if your MPG is suffering, then you have a problem.</TD></TR></TABLE> this would also minutely show that why it happens in gear acceleration changes velocit espicially of the "bobber" your cracked manifold = gas leaking out shouldnt cahnge fuel economy. Also how do you know its bad MPG? or do you mean just bad reading
Old Mar 30, 2007 | 01:34 PM
Default Re: Fuel mileage problem please help!! (89efDUSTY)
its my gauge its always going down and back up only when i am half empty. but today i full tank it and im going to see if it still a problem. thanks guys for your help.
Old Mar 30, 2007 | 01:41 PM
ZMX's Avatar
ZMX
My 1993 Civic DX is the same. If I stomp on it, the gas gauge goes down by about 1/5, and if I slam on the brakes, it goes up by 1/5. I don't think it's that big of a deal.
Rikaro
Aug 31, 2007 04:44 PM
w0ng_sta
Jun 16, 2006 05:04 PM
sicivic
Jun 8, 2004 08:43 PM
ActiveAero
Jul 3, 2003 11:27 AM
