installing coilovers on EP...
Old Mar 29, 2007 | 10:51 AM
cam3ron88's Avatar
Default installing coilovers on EP...
Ok, I just got some skunk2 coilovers(please no bashing the skunk2 I know there not the best but its what I got.) I was attempting to take off my stock struts and I could not get the tierod end/ball joint that coonects to the strut off...Does anyone have any advice on how to get them apart? thanx, much appreciated
Old Mar 31, 2007 | 02:18 PM
2004CivicHBSi's Avatar
Default Re: installing coilovers on EP... (cam3ron88)
Need a puller to pull down it so it pops it off. It's compressed on there somewhat. Try not to damage the threads and replace the cotter pin.
Old Apr 2, 2007 | 05:42 AM
Mugen Dom's Avatar
Default Re: installing coilovers on EP... (2004CivicHBSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2004CivicHBSi &raquo;</TD></TR><TR><TD CLASS="quote">Need a puller to pull down it so it pops it off. It's compressed on there somewhat. Try not to damage the threads and replace the cotter pin.</TD></TR></TABLE>This is not the best way....Beating on the Arm with a hammer to shock the tie rod is the safest way to get it out of the arm...no damaged threads and no renting or whatever of tools
Old Apr 2, 2007 | 08:20 AM
elpanopticon's Avatar
Default Re: installing coilovers on EP... (JdMK20Ahatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdMK20Ahatch &raquo;</TD></TR><TR><TD CLASS="quote">This is not the best way....Beating on the Arm with a hammer to shock the tie rod is the safest way to get it out of the arm...no damaged threads and no renting or whatever of tools</TD></TR></TABLE>
What I did as well. Just make sure to be careful when you strike the arm not to hit the tie rod itself or else you will ruin the threads. Just to warn you, it may take a little time for the rod to become loose.
Old Apr 2, 2007 | 11:20 AM
cam3ron88's Avatar
ok thanx for the help...a couple hits with the hammer did the trick pretty quickly, now I have another problem...when i go to connect the tierod end to the new coilovers how do i keep the ball joint from swivelling when I screw the nut back on the tie rod? this is really turning into a pain in the ***
Old Apr 2, 2007 | 12:35 PM
Mugen Dom's Avatar
just push down on it with your hand helps to have air tools
Old Apr 2, 2007 | 01:48 PM
^^^ Yep, thats pretty much it.
Old Apr 2, 2007 | 02:21 PM
cam3ron88's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdMK20Ahatch &raquo;</TD></TR><TR><TD CLASS="quote">just push down on it with your hand helps to have air tools</TD></TR></TABLE>
ok thanks I am going to go give it a try...
Old Apr 2, 2007 | 09:06 PM
pat.ter.rick's Avatar
beat it out...take like a ball peen or brass..and hit directly on the arm that comes out from the strut and connects to the tie rod..make sure you dont hit the tie rod..hit it hard couple times and it should pop out
99fbpem1
Nov 14, 2007 04:45 PM
vyxx-ct
Honda Civic (2001 - 2005)
Nov 29, 2006 08:08 PM
Sassafrass
May 27, 2005 10:42 AM
honda89
Aug 3, 2004 06:30 PM
1hotintegra
Mar 28, 2004 07:43 PM
