A/C Problem. Whirring sound, not very cold air.
Old Mar 29, 2007 | 08:59 AM
M2B4's Avatar
Default A/C Problem. Whirring sound, not very cold air.
Ok so i changed out most of my system to r134. evap, dryer, and compressor. I replaced the pressure switch bc it was bad and i charged the system with some quick charge kit. filled it to full and its blowing slightly cold air nothing spectacular. when i turned it off full blast i can here a whirring sound that sounds like its coming from the dash area. it goes whir....whir.....whir....whir (about ever 2 seconds) any one have an idea what that is?
Old Mar 29, 2007 | 09:30 AM
PrettyLude's Avatar
take out the cabin filter, there is some leaves are trash in there. did you vaccum the system before charging?
Old Mar 29, 2007 | 10:03 AM
M2B4's Avatar
Default Re: (PrettyLude)
no i did not vacuum, where exactly is the filter? i dont think 4th gen has a filter actually
Old Mar 29, 2007 | 03:20 PM
PrettyLude's Avatar
every car should have a cabin filter, it will not be as cold if you didn't vacuum it
Old Mar 29, 2007 | 03:32 PM
mattsnooz's Avatar
your Fan blows well though right? so its just blowing not so cold air though?
Old Mar 29, 2007 | 11:02 PM
M2B4's Avatar
Default Re: (mattsnooz)
i guess it blows well. it blows lol never had ac in a lude b4 i know my bros air blows alot stronger then mine he has an eclipse. the air is so so not very cold but not just blowing warm air through
Old Mar 30, 2007 | 03:08 AM
mattsnooz's Avatar
Default Re: (M2B4)
its probably your blower moter in your center counsol if air isn't moving into your cabin (the whirring is the fan blades slipping off the motor shaft in your blower. as far as coldness you just changed it over so it should be full of refridgerant so it must be something else mechanically wrong. when you fire up your ac and turn your fan on go to by your battery and look through the scope hole at your ac fluid. if you see it moving (the green fluid) let us know Also make sure your air is confined to internal circulation (button right beside AC button). If no fluid is moving through the scope then make another post here and ill see what i can tell ya. I replaced my fan after hearing similar sounds and the AC blew wicked sic. Frosty eyebrows for all y'all .
Old Mar 30, 2007 | 06:38 AM
M2B4's Avatar
yeah i can see movement in that lil hole. hrm i guess lemme find a new blower motor try that. lol A/C is retarded.
Old Mar 30, 2007 | 01:33 PM
mattsnooz's Avatar
Default Re: (M2B4)
lol,..its cool when it works
m.glisson003
Oct 13, 2011 12:01 PM
pd0019
Honda CR-V & Element
Sep 21, 2011 06:59 PM
ccasey3655
Aug 23, 2010 10:27 AM
LUDER INTRUDER
Jun 24, 2005 01:24 AM
Bull_head360
24
Apr 12, 2005 10:58 AM
