Clutch won't fully disengage when hot
Old Mar 29, 2007 | 03:20 AM
Del Sol's Avatar
Default Clutch won't fully disengage when hot
The setup in my Del Sol VTEC is a Spec stage 3 (6 puck ceramic) clutch, with a Fidanza aluminum flywheel. When the car has been running for a while, I start having problems with the tranny.
Hard shifts start grinding slightly, and reverse gives a large shudder/grind as you push it in (car stationary). I assume this problem is caused by the clutch not fully disengaging. It has only started doing this in the last few months, and as I said only when hot.
Anyone have any ideas before I pull the tranny? So far I have replaced the clutch slave cylinder, replaced and bled the clutch fluid, and replaced the tranny oil. The clutch master cylinder has also been recently replaced.
John.
Old Mar 30, 2007 | 02:04 AM
Del Sol's Avatar
Default Re: Clutch won't fully disengage when hot (Del Sol)
Anyone?
Old Mar 30, 2007 | 07:06 AM
pane93civhb's Avatar
im having a similar issues with a car im working on. Only it wont go into gear when the car is on. Shifts fine when the car is off.
When i put it in gear then start it the car moves just fine but wont shift.
Old Oct 15, 2007 | 08:10 PM
jdm_vtec's Avatar
bumping an old thread because i'm having the same problem
Old Oct 15, 2007 | 08:37 PM
all-mtr-teg's Avatar
Default Re: Clutch won't fully disengage when hot (jdm_vtec)
Clutch disk is saturated or contaminated maybe.
Old Oct 15, 2007 | 08:53 PM
jdm_vtec's Avatar
well i'm having similar problems during long (hot) rides, but instead of grinding my tranny will not shift without massive force.. if I shut the car off it will go into gear
I got the exedy organic clutch kit really cheap from a seller here on h-t marketplace, so i'm guessing that's what I get for being a cheap ***.
Old Oct 16, 2007 | 01:47 PM
Default Re: (jdm_vtec)
I got a brand new ACT AI4-XXSS clutch kit for B-series, make me an offer if you're interested.
Old Oct 16, 2007 | 02:03 PM
jdm_vtec's Avatar
well i have a t3/t4 turbo going on soon, so unless you have a clutch rated 50% clamping over stock and a 6 puck i'll be buying one from mike at LSD motorsports
i appreciate the help though
Old Oct 16, 2007 | 02:26 PM
The AI4-XXSS (XX) means x-treme pressure plate, rated 50-120% more clamp load over stock, (SS) street and race full faced disc
check it out
http://www.advancedclutch.com/...#1702
Asking 360 shipped or make me an offer.
MugenGTR
Jan 29, 2012 02:14 PM
lancerkid06
Dec 27, 2009 05:47 PM
Dc295kid
Dec 19, 2009 07:05 AM
H23vtecEG
Aug 15, 2005 01:30 PM
monEmakindave
May 6, 2004 12:10 PM
