Euro R Intake mani questions
Old Mar 28, 2007 | 08:46 PM
Honda_Fanatic's Avatar
Default Euro R Intake mani questions
Are the - Throttle Position Sensor and Fast Idle Thermo Valve from any other vehicles compatible?
I may need to replace them and want to know where to find them.
Is the Throttle Body the same as the standard USDM H22a1 or H22a4 throttle body?
Old Mar 28, 2007 | 08:58 PM
Default Re: Euro R Intake mani questions (Honda_Fanatic)
Just in case I named the Fast Idle Valve incorrectly.
That is what it is called correct?
Old Mar 28, 2007 | 09:45 PM
my9thtry's Avatar
.idle air control valve is what i belive the abreviation stands for and if need be i know you can either delete the IACV or buy/make an adapter plate for a US one to fit. those are the only options i have found. good luck, Joe.
Old Mar 28, 2007 | 09:51 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my9thtry &raquo;</TD></TR><TR><TD CLASS="quote">.idle air control valve is what i belive the abreviation stands for and if need be i know you can either delete the IACV or buy/make an adapter plate for a US one to fit. those are the only options i have found. good luck, Joe.</TD></TR></TABLE>
Thanks - any info on where to get this adapter plate?
Delete the IACV? Won't that mess up your idle completely?
Also anyone know the Stock Throttle Body size on the Euro R?
Old Mar 28, 2007 | 09:53 PM
nonvteclude's Avatar
no alot of us dont use it. most aftermarket tb dont even have a spot for them
Old Mar 28, 2007 | 10:02 PM
98vtec's Avatar
moderator emeritus
u can delete the fast idle. You cant delete the iacv completely without a script for it.
Old Mar 28, 2007 | 10:06 PM
Default Re: Euro R Intake mani questions (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">u can delete the fast idle. You cant delete the iacv completely without a script for it. </TD></TR></TABLE>
Right on - the one I am talking about is the fast idle and it can be deleted?
The IACV is on the other side of the mani and is required correct?
That makes scense. Thanks Blake
What do you mean by a "script"?
Old Mar 28, 2007 | 11:16 PM
Rosko's Avatar
I think he means script in whatever you're tuning with, i.e. crome, hondata...
the t.b. isn't the same as a usdm one, if you bolt the usdm t.b. on the euro-r the fast idle port on the usdm t.b. overlaps the casting and will cause a leak. Its not much though, you could get by using a little hondabond. The s2000 t.b. bolts up great, I have a few pics of it at home that shows a comparison.
Old Mar 28, 2007 | 11:22 PM
98vtec's Avatar
moderator emeritus
Default Re: Euro R Intake mani questions (Rosko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosko &raquo;</TD></TR><TR><TD CLASS="quote">I think he means script in whatever you're tuning with, i.e. crome, hondata...
the t.b. isn't the same as a usdm one, if you bolt the usdm t.b. on the euro-r the fast idle port on the usdm t.b. overlaps the casting and will cause a leak. Its not much though, you could get by using a little hondabond. The s2000 t.b. bolts up great, I have a few pics of it at home that shows a comparison.</TD></TR></TABLE>
yea, the s2000 doesnt have a fast idle. I just wish my s2k throttle had an idle adjustment screw
Old Mar 28, 2007 | 11:30 PM
Rosko's Avatar
I think you can install one, the hole is there it just isn't tapped or drilled through. It takes an M10 X .75 tap.
Old Mar 29, 2007 | 04:15 AM
PirateMcFred's Avatar
Rosko's right.
It should not be any trouble with a drill, tap, vacuum hose and a needle valve. The idle air screw is only a controlled vacuum leak. Everyone seems to have problems with uncontrolled Vac leaks. If you make one intentionally it should not be hard.
Pirate
Old Mar 29, 2007 | 08:14 AM
Rosko's Avatar
Default Re: Euro R Intake mani questions (PirateMcFred)
usdm on left, s2000 on the right
usdm gasket on Euro-R mani...
Old Mar 29, 2007 | 10:02 AM
my9thtry's Avatar
correct me if i am wrong but isnt what you circled in that picture the IACV?
Old Mar 29, 2007 | 12:19 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: Euro R Intake mani questions (my9thtry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda_Fanatic &raquo;</TD></TR><TR><TD CLASS="quote">
Is the Throttle Body the same as the standard USDM H22a1 or H22a4 throttle body?</TD></TR></TABLE>
You can also use a USDM ITR throttle body or a B16 t-b with no probs
Old Mar 29, 2007 | 12:33 PM
redtop22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda_Fanatic &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
when using a usdm iacv with the euror manifold what do you do with these two vacuum lines?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosko &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
also, if you run a s2000 TB do you simply plug the nipple?
Old Mar 29, 2007 | 07:42 PM
Default Re: Euro R Intake mani questions (cb7-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cb7-R &raquo;</TD></TR><TR><TD CLASS="quote">You can also use a USDM ITR throttle body or a B16 t-b with no probs</TD></TR></TABLE>
will a b16a throttle body work?
Old Mar 29, 2007 | 07:45 PM
So what about just changine the TPS with a JDM H22a one? Are they the same? I will probably have to drill and tap holes correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my9thtry &raquo;</TD></TR><TR><TD CLASS="quote">correct me if i am wrong but isnt what you circled in that picture the IACV?</TD></TR></TABLE>
Old Mar 29, 2007 | 07:49 PM
If a B16 throttle body works can't I use any B series? b18 b20??
Thanks
Old Mar 29, 2007 | 07:50 PM
Rosko's Avatar
why would you need to change tps sensors? they are the same.
Old Mar 29, 2007 | 07:55 PM
The TPS on the Euro R I just bought needs to be replaced.
Also the seller says the Fast idle is junk as well.
Old Mar 29, 2007 | 07:59 PM
Rosko's Avatar
ahh, you shouldn't have to tap anything. its a screw that holds it on there, just a tamperproof head. you just have to grind the head off, remove the tps, and unscrew the rest of the screw. do that to both t.b.'s and find some new screws to mount the tps and then be sure to calibrate it.
Old Mar 29, 2007 | 08:02 PM
Rosko's Avatar
I'm not sure if the Euro-R iacv incorporates the fast idle or not, looks like it could. either way your gonna have ditch that iacv cuz the plug is different (3-wire vs 2-wire)
get an adapter plate and use the usdm iacv or just block it off altogether. don't worry about the fast idle either, its not needed.
Old Mar 29, 2007 | 08:05 PM
I am running crome so my tuner can eliminat the IACV? Is that right? How?
I am just wanting to get this all on the roll cause I wanna get tuned with this IM ASAP. Should I change the TB?
Old Mar 29, 2007 | 08:12 PM
Rosko's Avatar
if all that tb needs is a tps then fix it and use it. yank those hoses off there and cap it off, block off the iacv and your good to go.
I don't know anything about crome but I'm sure Blake could tell ya. (I'm guessing you can tho)
Old Mar 29, 2007 | 08:26 PM
Happen to know the stock bore of the Euro - R TB?
