88 CRX - rear tire camber (negative)
The rear tires are wearing inside , I'm thinking this is called negative camber ?
I heard a solution is to install washers on the upper mounting bracket.
How thick of washers would be needed ? Or should I test one at a time-
then go thicker. (hopefully corrects the problem)
thanks.
thanks.
EJK20R
Suspension & Brakes
Mar 19, 2006 10:26 PM
