sway bar clearance issue
Old Mar 28, 2007 | 08:11 PM
thetugboatcomplex's Avatar
Default sway bar clearance issue
My new exhaust makes contact with my st rear bar. I need to know how to fix the problem (makes a pretty nasty noise at low rpm).
Thanks in advance
-Chad
Old Mar 28, 2007 | 08:32 PM
.Manny.'s Avatar
Touching My Member
Default Re: sway bar clearance issue (thetugboatcomplex)
if you cant get the exhaust out of the way, wrap the bar with some heatwrap or something of that nature to try to reduce the vibration
Old Mar 28, 2007 | 09:32 PM
Default Re: sway bar clearance issue (.Manny.)
thats what i figured, just not sure about how to move the exhaust up. Thank you.
Old Mar 30, 2007 | 07:12 AM
grog's Avatar
i would go back to the exhaust shop and have them put the right bends on it. especialy if the shop put the exhaust on after the swaybar. they created your problem, so they better fix it for free or real cheap
Old Mar 30, 2007 | 07:20 AM
89efDUSTY's Avatar
Default Re: sway bar clearance issue (grog)
i had to change my custom exhaust when i put on my st bar...its normal they can reroute it...i got it done for 10 bucks and havent had a problem...also to pull it up you can replace those rubber holders "fudge i forgot the name" with shorter ones to pull it up... gl
Old Apr 1, 2007 | 04:09 PM
grog's Avatar
Default Re: sway bar clearance issue (89efDUSTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY &raquo;</TD></TR><TR><TD CLASS="quote">i had to change my custom exhaust when i put on my st bar...its normal they can reroute it...i got it done for 10 bucks and havent had a problem...also to pull it up you can replace those rubber holders "fudge i forgot the name" with shorter ones to pull it up... gl</TD></TR></TABLE>
i aslo had to do this, and i paid for it. but I would hope the shop would fix your problem for free since the bar was on already.
redlinexd
20
Nov 27, 2012 05:03 PM
mreed
Jul 17, 2011 03:18 PM
DSMkiller
Apr 7, 2008 01:12 PM
EG_93Civic
Jul 25, 2005 03:30 PM
91cvcsi
Jan 22, 2002 07:11 AM
