Suspension & Brakes Theory, alignment, spring rates....
Prelude rear upper control arm, stripped mount.. suggestions?
Old Mar 28, 2007 | 07:50 PM
GraphiteMW's Avatar
Default Prelude rear upper control arm, stripped mount.. suggestions?
I have a 92 prelude, I was installing my rear springs today when I was using the pitman puller to break the mount loose on the uca the puller sliped off the side and crunched a thread.. Anyways the nut won't thread on and it knocks off everytime it hits that groove , I believe its the 3-4 one up. Could I use a thread renewer on it to renew the threads? BTW Anyone knows the size of the thread/bolt I heard it was m10x1.25?
Old Mar 28, 2007 | 09:21 PM
Hawkze_2.3's Avatar
Default Re: Prelude rear upper control arm, stripped mount.. suggestions? (GraphiteMW)
Just use a die and redo the threads. Probably have to get a tap and die set...
H22Stew
Suspension & Brakes
Mar 16, 2008 11:15 PM
Takumi Fujiwara
Mar 25, 2006 11:39 PM
CobaltInfinity
May 8, 2005 08:44 PM
