testing blow by
Old Mar 28, 2007 | 03:44 PM
raphael's Avatar
Default testing blow by
how can i roughly check my b18c1 block for any blow-by on the piston rings while head is off of block and out of car? what about the valves while head is off of the block and out of the car?
Old Mar 28, 2007 | 04:24 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: testing blow by (raphael)
If the head's off, you cant really check blow by. You can check valve sealing by having the combustion chambers cc'd and see if any fluid leaks past the valves etc. Realistically, you should have had a leak down test done before you took the head off for a proper evaluation.
Old Mar 28, 2007 | 08:11 PM
raphael's Avatar
Default Re: testing blow by (00Red_SiR)
hmm.. i see... i guess im fuked then huh?
Old Mar 28, 2007 | 08:43 PM
arc_55's Avatar
yeah leak down test and compression test should have been done to confirm a healthy motor before removing the head. You have to pressurize it, but as far as i know there is no way you can do that with accurate results with the head and block serperated.
Old Mar 29, 2007 | 04:38 AM
idriveahonda's Avatar
Leakdown test is most accurate. You should do it with the motor together, much easier that way.
Old Mar 29, 2007 | 10:52 AM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raphael &raquo;</TD></TR><TR><TD CLASS="quote">hmm.. i see... i guess im fuked then huh?</TD></TR></TABLE>
Bolt the head back on and have the leak down test done.
9t4fodo
Feb 3, 2009 01:09 PM
007EG
Nov 6, 2007 04:20 PM
Tenji
Apr 22, 2006 07:23 PM
3rdGteg
12
Sep 29, 2003 08:00 PM
