Does 2000 P73 ecu have transponder/unique keys?
Old Mar 28, 2007 | 02:12 PM
4EN[sic]'s Avatar
Default Does 2000 P73 ecu have transponder/unique keys?
Someone on here wants to sell me their p73 for my 2000 Si. I was told today not to do it because I would need the special key and other stuff to make it work? Does this sound right?
Old Mar 28, 2007 | 02:17 PM
92TypeR's Avatar
FSAE
Default Re: Does 2000 P73 ecu have transponder/unique keys? (4EN[sic])
Why do you want to run an ITR ECU on your Civic Si? You will only loose power.
Old Mar 28, 2007 | 02:24 PM
4EN[sic]'s Avatar
Default Re: Does 2000 P73 ecu have transponder/unique keys? (92TypeR)
I have a B18C1 block with the b16 head. Figured a 1.8 ecu would be better for my setup, since I am not at 1.6 liters any more. Have a hook up on a p73 for 125 shipped. Figured why not since i am having a hell of a time finding an obd1 p72 for a decent price. Since the p73 does not look for the intake butterflies like the p72, that would be one less thing i have to worry about throwing a code?
Old Mar 28, 2007 | 02:43 PM
Comp97GSR's Avatar
P72 will not throw a code for the butterflies. If you would get an OBDII P73, what is wrong with an OBDII P72?
Old Mar 28, 2007 | 03:12 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: Does 2000 P73 ecu have transponder/unique keys? (Comp97GSR)
your best bet would be get a chipped ecu with jumper harness and have them put a type r program into the ecu
125-150 for ecu
80-100 for jumper harness
Old Mar 28, 2007 | 03:13 PM
iheartintegras's Avatar
Sounds like you're better off pickin mine up
Old Mar 28, 2007 | 05:45 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4EN[sic &raquo;</TD></TR><TR><TD CLASS="quote">]I have a B18C1 block with the b16 head. Figured a 1.8 ecu would be better for my setup, since I am not at 1.6 liters any more. Have a hook up on a p73 for 125 shipped. Figured why not since i am having a hell of a time finding an obd1 p72 for a decent price. Since the p73 does not look for the intake butterflies like the p72, that would be one less thing i have to worry about throwing a code?</TD></TR></TABLE>
you'll have cel at all times after removing immobilizer chip, thats the only way to make it work. i'm sure theres way to bypass all that and have no codes but don't know how.. you gotta know ecus
BrandonB16
Feb 17, 2009 05:33 AM
djviet2000
Mar 31, 2008 01:27 AM
MMB16A2
May 21, 2004 09:34 AM
Big Teggie
Oct 2, 2001 11:19 AM
