Stock Honda Alarm.
Old Mar 28, 2007 | 01:33 PM
RA217252's Avatar
Default Stock Honda Alarm.
2000 Civic SI
There is a ticking noise coming from inside the car. The noise never ever stops. What is this noise? How to make it stop? Also I'm trying to install my Keyless Entry system, and it's not working. Is this because of the ticking noise? Someone please help.
Old Mar 28, 2007 | 02:35 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: Stock Honda Alarm. (sheehan024)
you need to get under the dash and find were its coming from. Or located the fuse and unplug each one till it stops. Then find out what on that circuit that could be causing this
Old Mar 28, 2007 | 02:55 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
you need to get under the dash and find were its coming from. </TD></TR></TABLE>
x2... We're not mind readers here... You need to crawl up under there with a flashlight and find the source of said ticking...
And when you say that your keyless entry doesn't work, exactly what is happening or not happening? Now remember, when you respond, specifics are key here...
Old Mar 29, 2007 | 04:07 AM
perseverance's Avatar
sounds like a relay's getting a signal and magnetizing. are ur lights flashing? doors locking? horn honking? i think that's all that the factory alarm does.
Old Mar 29, 2007 | 06:25 AM
fcm's Avatar
fcm
Old Fart
Ditto the above, more info...
1- When is it "ticking", all the time, when key is turned to acc., when key is turned to run, when car is started?
2- Where under the dash is it comming from drivers side, pass. side, center?
3- Was it there, [ticking] before you tried to install key-less entry system, or after?
4- As already asked, what exactly is happening or not happening with the key-less, and what is the make and model of the key-less entry system? 94
xunkn0vvnx
Oct 18, 2017 08:20 PM
WIhondas
Honda CR-V & Element
Jul 29, 2013 04:58 AM
joeyttw
Nov 4, 2006 07:06 AM
mayh3m
Apr 2, 2006 04:49 PM
