ANYONE FROM MCHENRY/LAKE/OR LOWER WIS.
Im in need of assistance, im having dizzy problems with my car... i live in Spring Grove, IL 60081. my car is a 91 rex with a Y5 bottom end and a Y8 head, Si tranny. the engine wiring harness dosent match the plugs for the dizzy, im trying to get this figured out... if anyone is willing to help, please let me know.
i have the d15 dizzy from my d15b which was in the car before the swap, only because it matches the harness, i also have an si dizzy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C_R_X_V_T_E_C »</TD></TR><TR><TD CLASS="quote">i have the d15 dizzy from my d15b which was in the car before the swap, only because it matches the harness, i also have an si dizzy...</TD></TR></TABLE>d15b vtec or the dx or hf motor
the engine harness was converted to obd1 by the previous owner, it has the ecu jumper harness from rywire.com... the dizzy plugs are for the d15b, but the only problem is that the dizzy from the d15b is too big for the bolt holes on the Y8 head... so i have a si dizzy, but the plugs dont match, what can i do?
You can't use that distributor if you are converted to obd1. I'm not sure which obd1 dizzy works with the y8 head. Do a search and you will find out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C_R_X_V_T_E_C »</TD></TR><TR><TD CLASS="quote">the t42 from a sohc vtec 92-95 civic.</TD></TR></TABLE>td42u
. which is the same dizzy for the d15b. You might have to make it fit
peter from rywire.com told me that i would have to send them my si wiring harness, my d15b wiring harness and buy a td42u dizzy for this to work, is there any way around that? or would sending them my stuff be the best thing to do?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C_R_X_V_T_E_C »</TD></TR><TR><TD CLASS="quote">peter from rywire.com told me that i would have to send them my si wiring harness, my d15b wiring harness and buy a td42u dizzy for this to work, is there any way around that? or would sending them my stuff be the best thing to do?</TD></TR></TABLE>if your engine harness already has obd1 plugs then the td42u should be plug and play. Can you take a picture of the plug connectors?
i can, but it has a 5 wire (round) plug, and a 4 wire (flat) plug... and i know the 4 wire one was added by the previous owner, and thats the main reason why im trippin about the dizzy...
t-town_ep
Nov 19, 2012 12:54 AM
C_R_X_V_T_E_C
Feb 21, 2007 03:54 PM
