finally got my stock d16z6@10psi dyno'd...
Old Mar 28, 2007 | 09:50 AM
wfocrx's Avatar
Default finally got my stock d16z6@10psi dyno'd...
I made 224whp/189wtq.
a/fs in the mid 11's under boost.
setup...
1995 d16z6
sls mini log manifold+2.5" downpipe+2.5" exhuast
1991 crx si tranny+xtd stg3 clutch+9lbs flywheel
t3/t04e 50trim .63 a/r
tial 38mm wastegate
greddy "ebay" rs bov
stealthmode oil lines
ebay fmic
550cc rc injectors
255lph fuel pump
crome+chippped p28
Old Mar 28, 2007 | 09:52 AM
wfocrx's Avatar
going to put on skunk2 IM+TB and p/p head w/ crower stg3 cam+retainers+springs in a couple weeks.
aiming for 275+whp at 10psi.
Old Mar 28, 2007 | 10:23 AM
D-booster's Avatar
Default Re: finally got my stock d16z6@10psi dyno'd... (wfocrx)
Do you have a graph of your dyno? I like to see power plots and what was total timming at for your 10 psi pull.
Old Mar 28, 2007 | 10:26 AM
D-booster's Avatar
Default Re: (wfocrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wfocrx &raquo;</TD></TR><TR><TD CLASS="quote">going to put on skunk2 IM+TB and p/p head w/ crower stg3 cam+retainers+springs in a couple weeks.
aiming for 275+whp at 10psi.</TD></TR></TABLE>
Good luck with that @ 10 psi, I think 13-15 psi will do it.
Old Mar 28, 2007 | 10:36 AM
wfocrx's Avatar
Iam working on getting the dyno chart scanned.
as far as timing it is running *1per/psi retard so IIRC it is somewhere around 18*
Old Mar 28, 2007 | 11:26 AM
D-booster's Avatar
did you tune it or some one else? and what is it tuned on?
Old Mar 28, 2007 | 12:06 PM
wfocrx's Avatar
tuned on crome.
phearable base map. 1*retard per psi and pig rich. air/fuel tuned by me and my brother. i run it a little richer(11:1) under peak torque and then lean it out to about 11.5:1
Old Mar 28, 2007 | 01:56 PM
EJ1 wilcox's Avatar
That's a killer number for 10psi.
Must be a well put together setup!
Good luck with it. I don't think I would personally push a stock d16z6 past where you have it. But it's been done before and I'm sure it will be done again!
Old Mar 28, 2007 | 03:29 PM
bnut510's Avatar
Default Re: (EJ1 wilcox)
is this the one with the video? where he says hes trying to blow the sohc motor but it doesnt wanna blow?
Old Mar 28, 2007 | 04:50 PM
TorganFM.'s Avatar
Default Re: (bnut510)
Screw that other stuff and just go with the IM and TB... I promise you.
Terrible One
Feb 22, 2010 04:42 PM
VTEC IS UR BEST FRIEND
Oct 16, 2007 03:57 PM
b16a4
Jan 14, 2007 01:34 PM
91crxracer
Mar 27, 2006 01:42 PM
vaporboy12
Aug 6, 2005 07:40 AM
