wiring
Old Mar 28, 2007 | 07:28 AM
kixcrx's Avatar
Default wiring
so im installing a d16a6 into my car and im connecting all the connectors but what i wanted to know is that where the oil filter goes in the back there is like three connections on top of oil filter the ones that look like sticks and there is one that takes two i was wondering that if it matters in what connection goes on what stick
Old Mar 28, 2007 | 07:32 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: wiring (kixcrx)
Your wording is a little confusing. However, it does matter which ones go where. You should have your oil pressure sensor and fan switch on the back of the block there, not exactly sure about the other one. The oil pressure sensor should be a single pin, the fan switch should have two pins. I haven't had a D16A6 for three years though so I'm just going off recollection
Old Mar 28, 2007 | 08:49 AM
kixcrx's Avatar
Default Re: wiring (wiZCo)
sorry about the writing its cause im doing this and installing my motor at the same time and yeah its the 2 pin one im talking about does it matter which one goes on which pin
Old Mar 28, 2007 | 10:30 AM
wiZCo's Avatar
Stouts 'n' Scotch
Look at this diagram: https://www.hondapartsdeals.co...E++06
Which one are you referring to?
Old Mar 28, 2007 | 01:25 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kixcrx &raquo;</TD></TR><TR><TD CLASS="quote">sorry about the writing its cause im doing this and installing my motor at the same time and yeah its the 2 pin one im talking about does it matter which one goes on which pin</TD></TR></TABLE>
on the 2-pin for the fan switch, it doesn't matter which goes where
Old Mar 28, 2007 | 03:20 PM
kixcrx's Avatar
Default Re: wiring (jlicrx)
in that picture wiring thing its number 22 the one that sits on top of oil filter so it doesnt matter
cehcivic15
26
Aug 18, 2020 04:57 PM
M-benz
Oct 8, 2013 04:56 AM
T-Mo
May 27, 2012 04:05 PM
lilczar
Aug 23, 2010 11:48 AM
mister m 83
Apr 20, 2009 03:21 PM
