new tranny is lsd, what axle seals do i use?
Old Mar 28, 2007 | 05:58 AM
d16t-hatch's Avatar
Default new tranny is lsd, what axle seals do i use?
ok i just put a new motor and tranny in my car cause my oil feed cracked off the back off the block and i ran the motor for like two weeks like that, it was still running good when i took it out just wouldnt hold oil. So now my cars already leaking oil again its been like one day driving it. But the new tranny im almost 100 percent sure is lsd. My tranny's leaking alote of oil like all of its gone after driving probally 2 miles and i think its coming from the axle seals. And i went to buy new ones from honda but i dont know what to buy them for i have regular 92-95 civic ex axles on a d16z6, the tranny i put in says s20 on the bellhousing but on the gearbox itself says like y4f and p20 im trying to search right now and find out what the tranny is out of and if i need diffrent axles, also i need to know what axle seals i need to use for this tranny if i dont need new axles. the car has a fidanza light weight flywheel and spec 6 puck clutch. it makes a wining sound but i think its just the differential its tuff to tell cause it runs out of oil pretty fast then it just sounds like im in reverse the hole time.
Old Mar 28, 2007 | 12:31 PM
Bense's Avatar
axle seals depend on which transmission case and which axles.
Old Mar 28, 2007 | 07:03 PM
d16t-hatch's Avatar
the gear box case is p20 the bellhousing is s20 so idk if the tranny is like custem made and honestly i dont even know what the p20 trannys are out of, are they from a zc or somthing idk, the trannys already in the car with the axles in the axles are regular civic ex axles the motor is a d16z6, and like i said the tranny is s20 bellhousing wich is a normal ex tranny but the gearbox casing itself is p20 im gonna try new ex axle seals, im not really sure if its leaking from the axle seals tough
Old Mar 28, 2007 | 07:05 PM
d16t-hatch's Avatar
also i did a little research and the tranny might be out of a civic vti but i have know clue if that modle is edm jdm canadian or what so i have no clue how id order new seals or anything
Turbo Dan
Jun 13, 2012 03:20 PM
90civSi
25
Jan 16, 2006 03:35 PM
Shotman
Jan 15, 2005 03:50 PM
boostng r
17
Dec 27, 2004 10:19 PM
HT Chaplain
Aug 24, 2004 06:05 AM
