Cam gears and Stock Cams.
Old Mar 28, 2007 | 03:49 AM
b16a4's Avatar
Default Cam gears and Stock Cams.
If i tune my stock cams with cam gears, will i notice any improvement?
what kind of settings should i put?
Old Mar 28, 2007 | 05:31 AM
Natural Aspirations's Avatar
Maybe, the best setting will be the ones which give you more power where you want it.
Worst question EVER, you don't even state what ******* motor you have...
Old Mar 30, 2007 | 11:41 PM
salman's Avatar
Old Mar 31, 2007 | 04:41 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (Natural Aspirations)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Natural Aspirations &raquo;</TD></TR><TR><TD CLASS="quote">Maybe, the best setting will be the ones which give you more power where you want it.
Worst question EVER, you don't even state what ******* motor you have...</TD></TR></TABLE>
Realistically he doen't need to state what motor he has since the question is simply asking if there's an advantage to using adjustable cam gears on stock cams.
On any engine, being able to adjust cam settings will usually be helpful in tuning for a little more power. The thing is you will need to have the car on a dyno in order to know what settings will work best for your car. There are no "standard" settings to use that will work for every car.
Old Apr 1, 2007 | 05:17 AM
b16a4's Avatar
Default Re: (00Red_SiR)
thanks bro!.
misterpsycho
Jan 14, 2008 10:54 AM
TRYLSTEG808
Jul 24, 2007 02:00 PM
hondacrx2
May 31, 2007 06:51 PM
blkwidow420
Apr 14, 2005 01:37 AM
insnimprtguy
Jul 17, 2002 02:11 PM
