Power Steering Removal
Old Mar 27, 2007 | 07:05 PM
lude98SH's Avatar
Default Power Steering Removal
Ok guys sorry about the thousandth thread on this. This is a 5th gen btw. Anyway i have the lines looped on my power steering rack and have had it that way for about 6 months atleast with no problems. I am very happy i did the removal and it defly made the engine easier to work on and dropped some lbs also.
I have thought about trying to switch it over completelyto a manual rack but the problem is do i have to swap a whole rack assembly in there from a 4th gen ? Does that rack even fit ? And lastly what is the steering ratio of those manual racks ?
Old Mar 27, 2007 | 09:18 PM
Hawkze_2.3's Avatar
Default Re: Power Steering Removal (lude98SH)
Dude, there is no manual rack. You have to take apart the rack and convert it yourself.
Old Mar 28, 2007 | 06:12 AM
lude98SH's Avatar
Default Re: Power Steering Removal (Hawkze_2.3)
sorry i thought a model of the 4th gen came with it. Is the power steering rack for a 5th gen the same as a 4th ?
Old Mar 28, 2007 | 08:10 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">sorry i thought a model of the 4th gen came with it. Is the power steering rack for a 5th gen the same as a 4th ? </TD></TR></TABLE>
I would assume it's pretty similar...maybe not identical.
Old Mar 28, 2007 | 08:16 AM
lude98SH's Avatar
ok thanks man ill look into it.
Old Mar 28, 2007 | 08:19 AM
mgags7's Avatar
you have to convert the 5g rack just like I converted the 4g.
The 5g rack is much simpler though, it doesn't have that retarded speed assist steering crap.
Your main objective is to get rid of that seal on the rack, there is a piston on it that seals with an outer housing, cut the seal off, grease the insides with thick synthetic grease, wheel bearing grease works great...
Old Mar 28, 2007 | 05:14 PM
lude98SH's Avatar
Default Re: (mgags7)
and its held up good for you ?
Have you done this yourself on a 5th gen ?
Old Mar 28, 2007 | 06:44 PM
98vtec's Avatar
moderator emeritus
Default Re: (lude98SH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">and its held up good for you ?
Have you done this yourself on a 5th gen ? </TD></TR></TABLE>
same concept different model.
lude98SH
Sep 19, 2008 05:52 PM
jjspec
Dec 4, 2007 01:00 PM
kornerk12
Feb 13, 2007 10:11 AM
rexorz
Jul 31, 2003 01:23 PM
OzzieAccord
Sep 24, 2002 09:53 AM
