Stumped
Old Mar 27, 2007 | 06:09 PM
Booz's Avatar
Default Stumped
I recently bought an 89 crx si, and coincidently I noticed a couple guys w/ the same problems recently but not quite the same. My car will occasionally seem to sputter like it's not getting gas when I'm casually driving it. I thought it might be the fuel filter being clogged so I changed it. This happened once, but has happened twice as of lately- once I cut off my car to get gas or a drink (something quick) and hop back in my car I will go to start it and it will fire up but then die before I can rev it. The solution I have right now is to let it sit for a min w/ the key out and then try and it fires up fine?
Also, when I'm starting it cold it seems to fire up fine as well. I think this may be the fuel pump?
Lastly, does the holes on the bolts to the fuel filter need to be in line w/ the holes on the end of the fuel lines?
Old Mar 27, 2007 | 07:50 PM
danmdevries's Avatar
Default Re: Stumped (Booz)
Can't really help you as it doesnt' sound like a problem I've encountered personally.
But as far as the banjo fittings, no, you don't need to line up the holes.
Old Mar 27, 2007 | 07:53 PM
boostedblkef's Avatar
Default Re: Stumped (danmdevries)
could be dizzy when its warm mine used to not rev up abouve 4k when warm
Old Mar 27, 2007 | 07:54 PM
freshly boosted DOHC ZC's Avatar
having the same problem but its not every day just when its warm out or i run the car hard
Old Mar 27, 2007 | 08:01 PM
91ed9's Avatar
Default Re: Stumped (almost boosted DOHC ZC)
somethin like that happens to me when im driving casually sometimes it bogs but then i let of the gas a bit and then hit the gas again and it stops or if i keep on the gas it will bog and then wipe me back in the seat and take off lol
i think it might be the dizzy i really dont think its the fuel problem
Old Mar 27, 2007 | 11:00 PM
cr-x-91's Avatar
check ur timing belt and c if its too loose and has alot of slack,this could couse slight retardation of timing since the cam needs to wait for the slack than turn.
Old Mar 27, 2007 | 11:20 PM
xotic_crx's Avatar
Default Re: (Booz)
I'm interested here too, mine recently started doing the exact same thing. It started with the bobbling on throttle, since has quit, but will have the same problem starting yours does. Mine also has a stupid idle sometimes, any weird idle problems too?
Old Mar 28, 2007 | 02:07 AM
Booz's Avatar
Default Re: Stumped (91ed9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91ed9 &raquo;</TD></TR><TR><TD CLASS="quote">somethin like that happens to me when im driving casually sometimes it bogs but then i let of the gas a bit and then hit the gas again and it stops or if i keep on the gas it will bog and then wipe me back in the seat and take off lol
i think it might be the dizzy i really dont think its the fuel problem</TD></TR></TABLE>
This happens too. And I do the same thing, letting off the gas and then give it gas again and it does alright.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xotic_crx &raquo;</TD></TR><TR><TD CLASS="quote">I'm interested here too, mine recently started doing the exact same thing. It started with the bobbling on throttle, since has quit, but will have the same problem starting yours does. Mine also has a stupid idle sometimes, any weird idle problems too?</TD></TR></TABLE>
I do have a rough idle sometimes, but not all the time, when sitting a stop light or something.
Old Mar 28, 2007 | 02:33 AM
Booz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danmdevries &raquo;</TD></TR><TR><TD CLASS="quote">But as far as the banjo fittings, no, you don't need to line up the holes. </TD></TR></TABLE>
Thanks
Old Mar 28, 2007 | 04:45 AM
SIRX's Avatar
not sure if it will help on My toyota i had a similiar problem. come to find out the fuel pump was dying. just a thought
Old Mar 28, 2007 | 05:01 AM
Booz's Avatar
Default Re: Stumped (SIRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIRX &raquo;</TD></TR><TR><TD CLASS="quote">not sure if it will help on My toyota i had a similiar problem. come to find out the fuel pump was dying. just a thought
That was my intial thought, haven't gotten around to check it yet though. It being in the gas tank means it will prob. take me longer than I have time for right now.
Old Mar 28, 2007 | 05:39 AM
ChickenH's Avatar
The main relay can cause this problem. resolder it ,its easy. it randomly turns the fuel pump off or gives it low voltage causing intermitent no starts surging bucking etc.
dylaxiin
20
Apr 27, 2011 04:48 PM
89b20crx
Mar 8, 2011 09:54 AM
turboteg7
Jan 3, 2009 03:37 AM
Xenobi
Jan 26, 2006 09:24 PM
red92EG
Jan 16, 2006 07:59 PM
