Replacing Wheel studs.
Old Mar 27, 2007 | 05:07 PM
NAlover's Avatar
Default Replacing Wheel studs.
Well guys I need some help... I've changed wheel studs before but not on a honda.
I have to change 2 in the front. is there anyway easier than taking the hole HUB apart???
Old Mar 27, 2007 | 05:19 PM
JDM94HATCH's Avatar
Default Re: Replacing Wheel studs. (NAlover)
na man u gotta take off the whole hub
Old Mar 27, 2007 | 05:28 PM
NAlover's Avatar
Default Re: Replacing Wheel studs. (JDM94HATCH)
I heard something about grinding a lil bit off the HUB so you can just get it to come out...
How does this work??
Old Mar 27, 2007 | 05:35 PM
turbociviccoupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAlover &raquo;</TD></TR><TR><TD CLASS="quote">I heard something about grinding a lil bit off the HUB so you can just get it to come out...
How does this work??</TD></TR></TABLE>
thats a loil ghetto the right way is to take the hub out.
but its exactly huw it sounds you grind a lil off the hub so the new studs will fit no problem.
Old Mar 27, 2007 | 05:43 PM
Snail Tuning's Avatar
you can sometimes cut alittls off the back of the old studs to pound them out past the hub/bearing. the same can be done when installing the new studs. if you look at the back of the hub you will see where the stud will hit the bearing/hub. just notch the back and pound away.
Old Mar 27, 2007 | 05:52 PM
NAlover's Avatar
Default Re: Replacing Wheel studs. (Snail Tuning)
That sounds better. I know the right way is to take the hub apart, but I don't have too much time for that and I don't thing grinding a lil bit will hurt the hub's performance ...
Old Mar 27, 2007 | 05:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAlover &raquo;</TD></TR><TR><TD CLASS="quote">That sounds better. I know the right way is to take the hub apart, but I don't have too much time for that and I don't thing grinding a lil bit will hurt the hub's performance ...</TD></TR></TABLE>
just as long as you dont grind all the way to the bearings lol
Old Mar 27, 2007 | 06:02 PM
NAlover's Avatar
Default Re: Replacing Wheel studs. (turbociviccoupe)
GeGeGeGe!!! I'll make sure I don't grind too much..
thanks anyway
Old Mar 27, 2007 | 06:07 PM
Kafelatte's Avatar
take your time and take the whole hub out. better safe than sorry.
Old Mar 28, 2007 | 05:08 PM
JDM94HATCH's Avatar
Default Re: Replacing Wheel studs. (Kafelatte)
x2
cmfnelson
Nov 24, 2012 01:03 AM
jdmtodadc2
Aug 26, 2012 01:21 PM
ef90b16
Nov 28, 2008 09:36 PM
fit2slo
Honda Fit
Oct 28, 2008 10:56 PM
ekim952522000
Jun 21, 2006 06:30 PM
