DA owners
From: oklahoma city, oklahoma, united states of america
ok i have searched and searched for some time now and im still wondering if there is any other way to remove the alternator without having to remove the axle or drain any fluids. I just purchased my 90 integra rs and it has 85000 miles on the b18a1 but the alternator just went out and i need help. sorry im not the best when it comes to fixing cars...
I have heard two other ways, not sure if they work tho. You can unbolt the bracket that the alternator bolts to from the block, then if you get the alternator at the right angle, it will come up and out. The other way is to unbolt the intermediate shaft bolts and twist the bracket out of the way, then with the alt. at the right angle, it will drop out. Let us know what works for you.
i just did this this summer...no removing axle or draining fluids..
pop the lower ball joint, and as a whole unit, swing the knuckle/rotor/caliper/axle out and to the right. you'll be pulling the axle out of the intermediate shaft but leaving it through the hub and swinging the whole unit out of the way, if you can understand that.
change alternator and install is just the reverse.
oh and get a helms itll tell you how to do it step by step and it involves removing the axle, its really not that bad. a friend is always helpful too
I have taking the alt through the top and bottom without removing the axles. only thing I removed to get it through the bottom was the exhaust manifold down pipe. easy as pie
yeah, I have seen someone on G2IC.com do it. You do not have to remove the axle or manifold. According to what I saw, you just unbolt the halfshaft and that should give you the room needed to get it out. Or you can just check out the website!! There are picks of the procedure.
i unbolted all the bolts holding the brace on the engine block but its getting stuck at the bottom of the by the driver side axle. but by reading your post i think i can squeeze it out. I just gotta find the right angle. is removing the exhaust downpipe hard? or should i try a different method?? THANKS FOR THE HELP.
MR_Se7en
Mar 25, 2008 10:04 AM
97VtecIN
Nov 7, 2004 08:52 AM
